Question about Brother Office Equipment & Supplies
BROTHER MFC 9050 FAX MACHINE. Although toner and drum have been changed, when printing it misses about 1cm of print to the far left side of the document which makes it difficult to make out what's there. The rest of the document is also very faint.
    Problem Solver:
  • 11 Answers
1.Check setting of printer to side of paper setting
2.Try to remove toner and check if the toner is coming out well
Posted on Dec 31, 2012
    Genius:
  • 2,120 Answers
Sounds like a bad toner cartridge. Hold it over a big trash can and shake it side to side. Use only GENUINE Brother carts.
Posted on Nov 11, 2008
  • Leroy Elliott
    Leroy Elliott Nov 14, 2008
    Why did you rate this inappropriate?
  • Leroy Elliott
    Leroy Elliott Jan 31, 2009
    ID 10Ta Ka Mo ROn
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
I have a Brother MFC 8220 with a nonBrother cartridge and the original Brother drum. No problems printing until today. I tried to send a 4x6 piece of thin card stock through the front manual feed on the...
There are possibly 2 reasons why this is happening.
1. The drum unit may have been damaged in some way but I doubt it. Check fully that all contacts are in the right place at either side of the drum unit. A contact may be slightly bent.
2. Check the Transfer Roller is in its correct position. The transfer roller is the felt type roller that is positioned in the printer under where the drum unit goes. If this has got out of position then that could also cause the faint printing. Check contacts in printer are not bent.
May 19, 2011 | Brother MFC-8220 Fax
I have a Brother mfc-8440. It prints light on the
Usually when it prints light on one side and normal on the other, it's either the drum (which you replaced) a dirty corona wire, or the toner is unevenly distributed in the cartridge. You can removed the toner cartridge and gently drop it from a distance of about 4-5 inches to dislodge any caked up toner. This is normal in a cartridge that has sat a while or if the fax machine is in a room with high humidity.
Hope this answers your question and best of luck.
Greg
Aug 02, 2009 | Office Equipment & Supplies
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Right side of printed page is faded
pull out your drum unit and look inside machine above where the drum would be. you should see a black assembly that runs left to right with a "****" glass. may need a flashlight. clean that glass off with a clean rag. sometimes toner "scatter" will get on glass and cause this.
let us know,
razors
Mar 26, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother MFC 8300 Fax Machine
No, the toner is clear on the whole page except for the right side where it fades out and you can barely make out the words. Everything else on the page is fine. The drum still has 17% of life left in it.
May 08, 2008 | Brother MFC 8300 Laser Printer
Brother MFC 9700
Remove your drum unit and you will see on top of where the drum unit sits inside your machine is a piece of glass(inside the machine). Wipe the glass with a soft dry cloth. If this do not work, remove your toner cartridge and see if the toner is spread evenly on the cartridge.
Mar 17, 2008 | Brother MFC 9700 All-In-One Laser Printer
Brother mfc 8500 clicking noises
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Jul 24, 2006 | Brother MFC 8500 All-In-One Laser Printer
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
