Question about Agfa ePhoto 307 Digital Camera
Flashing 254 on camera display
I just changed the batteries and was taking pictures and all of a sudden I hear a beep and see the display read a flashing 254. The battery icon shows a full charge. The flashing 254 does not change regardless what setting you put it on hi-lo etc... In the viewfinder the red light remains on. I connected the camera to the computer wanting to download the photos I did take and the software does not recognize the camera.
  • Agfa Master
  • 6,019 Answers
Try replacing the media card - may be corrupted
Posted on Jul 12, 2017
3 Suggested Answers
SOURCE:
jackboy
  • 2985 Answers
SOURCE: Pink Screen
This needs to be returned to the Vendor or Sony Direct for replacement
Posted on Jan 14, 2009
duane_wong
  • 6826 Answers
SOURCE: no flash when taking photos
If it shows the flash is on but it doesn't flash, check that you are allowing the internal capacitor to charge up by depressing the button for taking pictures halfway until the capacitor charges up. If it still doesn't flash the camera may need service at Agfa.com.
http://www.agfa.com/gs/en/internet/gs/about_us/worldwide/north_america/usa.jsp?title=%2Fgs%2Fen%2Finternet%2Fgs%2Fabout_us%2Fworldwide%2Fnorth_america%2Fusa.jsp&support=on&filter=true
I'm assuming you're in the USA for the above telephone number.
Good luck on repairing this problem on your Agfa camera.
Posted on Dec 25, 2010
We can see and hear, but the other party can only hear.
This is a new problem, as we have had the camera for 6 months, but suddenly, we can see and hear the connection, but the other party can only hear us. However, when I push the snap shot button I see the picture taken and the camera has the "on" light to the left (facing the... Read more
May 26, 2009 | Logitech QuickCam Communicate Deluxe...
It wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Sep 20, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
No Picture
1. If you are using TIFF mode for uncompressed images, the camera takes much longer to process the image because of the very large file size. It takes longer between shots and longer to play back a TIFF image. The TIFF setting on the camera Top LCD Display is 'No Stars' (One Star = Basic, Two Stars = Normal, Three Stars = High Resolution, No Stars = be patient for TIFF). Unless you are doing professional images, we suggest that you use the normal or high resolution JPG settings (Two or Three Stars / FULL) for good results. 2. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 3. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. 4. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
No Picture
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Cameras Logo
43 people viewed this question
Top Agfa Cameras Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
Harrie
Are you an Agfa Camera Expert? Answer questions, earn points and help others
