Question about Minolta Office Equipment & Supplies
Konica minolta bizhub c500 pro code sc27-01 also can not get into the service mode code numbers 9272 have been changed. it's a used machine that i just bought.
  • Minolta Master
  • 6,161 Answers
Check the sensor for the yellow drum open the middle then open the center then remove the transfer belt then the yellow drum top one. Then you will see a very small window sensor near the front of the drum area it will be on a silver/chrome little strip use air brush can air DO NOT USE VACUUM static can destroy it.
As the person you bought the machine from who serviced it then get the access from them. 9272 is the default.
OR
HOLD DOWN THE 2 and 5 and power the machine on keeping 2 and 5 down when Mode 25 Screen show select Soft Switch setting then enter a 3 in the first box then a 2 second box and select 0 this will remove the requirement for a password then exit power off the machine and wait ten seconds power on then if want to reset to original set 3 the 2 then 1 for 9272. Do not mess with and other number you can real screw things up. Recommend that you document what the setting where originally just incase you need a tech to come out. You can use the 3 and 6 button then power on for the 36 mode and 4 and 7 for 47 mode.
Posted on Dec 28, 2014
4 Suggested Answers
  • 7 Answers
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
Posted on Aug 22, 2009
  • 24 Answers
SOURCE: I am using a konica
Press this button in same order and sequence UTILITY-STOP-0-0-STOP-0-1
Where 0 mean zero of keypad then you see the msg "service mode" press down key and go to ADJUST and press OK press down key and go to ATDC and press OK check the value and increase some higher point again press OK press reset switch off and after some seconds switch on perform above actions until you get machine in ok condition or other otherwise you must be change the developer powder. but be sure to run atdc auto adjustment which is in SERVICE MODE-FUNCTION-ATDC AUTO ADJUST then press ok and leave the machine for complication his process,
Posted on Jan 27, 2011
SOURCE: I cannot tell what steps
The machine will scan to SMB as standard, scan to email would require the optional IP424 controller. Your service company should be able to set this up.
Posted on May 11, 2011
What is the default input password (service password) for bizhub 554e printer.
9272 four times.
Service Mode password for new series Konica Minolta Bizhub series is "9272927292729272."
Dec 20, 2016 | Konica Minolta bizhub Office Equipment &...
I need a technician in metro atlanta who has expierence with konica minolta c500 or 8050
contact the manufacturer we have no idea who does that service for them anywhere
Nov 17, 2015 | Konica Minolta Bizhub Pro C500
How to unlock CE authentication password?
your best option is to contact Konica and ask them if there is a fix to what you have done to it .
Sep 29, 2015 | Konica Minolta Bizhub C280 Color Copier /...
What is the utility key when trying to reset a fuser abnormality code on my konica minolta pro c500
Sir,
TO reset that code on C500 is not done with the utility button.
1. First power off the machine.
2. Hold down the 2 and 5 button and power on the machine.
3. Wait for screen then select Soft switch settings.
4. See a new screen, in the first box on your left put a 3
5 in the second box put a 1
6. In the third box you are going to change the 1 to a 0.
Exit. power off the machine. Wait ten seconds power on. If the code comes back have a technician look at the machine do NOT RESET again you are resetting the codes for the Fusing unit the Hot part could CATCH on FIRE!!!!!!!! or do more damage to circuit boards.
Sep 11, 2014 | Konica Minolta bizhub Office Equipment &...
SMTP setting in Bizhub C500
Go to Self Help Product Support Konica Minolta Business Solutions Inc you can get pdf file of the operation manual so you instructions on how to do that. Can also contact them
Feb 26, 2014 | Konica Minolta bizhub Office Equipment &...
Scanner settings Bizhub Pro C500
The communication can only be complete when the IP Address is fully established. This is in the manual and information on doing a set up is detailed by Minolta. Only you or a technical person with privileges who you invite into your computer can resolve that issue.
Feb 20, 2014 | Konica Minolta Bizhub Pro C500
348 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
