Question about RCA Televison & Video
I have an RCA DRC 618N Portable DVD player. It pauses and skips all the time and wont even recognize home made DVDs.I get the message BAd Disk with some disks, is this common? Any solutions??? It is hard on road trips when it keeps skipping and then pausing constantlly.
  • krisser40 Nov 11, 2008
    Is this an expensive thing to fix??Or should I get a new one?
    Habit-Forming:
  • 166 Answers
THE MOST COMMON CAUSE WILL BE THE OPTICAL PICK UP (LASER) NEEDS REPLACING
Posted on Nov 11, 2008
Sony dvp-fx811 portable dvd player, use to work fine, unfortunately it may have been dropped but was in a soft carry case, now either a dvd wont play and the player says "cant read disk" or if it does play...
Sounds like the optical drive either needs 1 of 2 things. (1)Try cleaning the optical drive with a cleaning kit (2) replace the optical drive. However it may cost more to replace/repair it that it is worth...
Aug 03, 2010 | Sony DVP-FX811K 8 in. Portable DVD Player...
Polaroid DVD Player PDM-0742 not playing dvds
I was a circuit board engineer for the on-chip set. there was a major techical issue with the units but due to the cost of investments by polariod, they decided to sell them to the public anyway. the promblem is in the chip that only works for a very short time before is overheats and the system will show "bad disk"
Jan 23, 2009 | Polaroid PDM-0742 Portable DVD Player
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Drc 286 does not recognize dvds
have you tried to use a laser lens cleaning disc?
otherwise it will have to be opened up and manually clean the laser lens with the lens cleaner and a cotton tip
electech
Nov 26, 2008 | RCA Televison & Video
Panasonic dvd player, wont play error code HO3 keeps coming up, took it back to shop they wont help as cant find receipt
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Oct 17, 2008 | Panasonic DVD-LV50 Portable DVD Player...
No Disk error message
I have the same problem. I opened the DVD player up and "blew out" dust. Still does not recognize that I have a disc in. HELP
Aug 27, 2008 | Onkyo DV-C601 Multi-disc DVD Player
DVD player won't work
same problem as above===put disc in and get no disc or error disc also mine will read then just stop
Dec 30, 2007 | RCA DRC6300N DVD Player/VCR
DVD DRC630N
Hey, this looks familar. Here's the same answer (first)....
Sometimes this is a dirty surface on the Disk. Watching it with a soft cloth and non-abrasive 'gentle' dish soap can help. At least, that's what Netflix tells me to do with them.
If it's happening on EVERY disk, and all you're playing are commercial, new, pre-recorded DVDs, then there's more things to try. Some links from reputable sources:
http://www.techlore.com/article/10478/
http://www.ehow.com/how_2036277_fix-error-dvd.html
After all that fails, it's probably time to change the DVD drive inside the player. Sometimes this is easy, sometimes not. :) with the DRC 630N, this would be more in the 'not' arena. :)
Of course, if you have a valid warranty, then when you're left with no solutions that don't void the warranty, you have to decide whether to try to pass it off to the warranty holder for repairs.
But, with more information....can you still play the games that this unit comes with? Assuming so, then the problem is probably one of alignment of the read sensor. This is generally a repairman fix.
RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Aug 22, 2007 | RCA DRC-285 DVD Player
Televison & Video Logo
419 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
