Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Can't get a straight stitch. too loopy.
I have no manual for help. How is the tension increased? The dials have numbers. Should I increase the number to get more tension or lower it?
Diane
    Problem Solver:
  • 4 Answers
Yes, a greater number will be more tension, i find it helps to use four different color of threads so that it is easier to see the change in the adjustment that you make. be positive that the machine is threaded correctly and the thread is IN the tension disc, very easy to overlook. hopes this helps
Posted on Jan 28, 2009
Brother ls 2020, 3 dials for tension, ALL I WANT TO DO IS MEND. what is the # just for mending? why are these machines so hard to work?
A manual may help:
User Guide Manuals LS 2020 Others Brother
There is only one tension dial, the round knob above the needle. Standard setting is the midway point between high & low number. The other two knobs are the stitch length and stitch width dials. With the stitch length knob, zero will make the machine sew in the same place, so you'll want to set it probably midway (the higher the number, the longer the stitch). With the stitch width dial, zero will sew a straight stitch--the higher the number the wider the stitch). Spend about 30 minutes reading the manual and you'll probably be able to use your machine. ALWAYS RAISE the presser foot when threading the top thread so the thread will seat properly.
A video may also be helpful:
https://www.youtube.com/watch?v=UC4ci-t5M60
RELAX!!!
Mar 30, 2017 | Brother Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
When I embroider with my Pfaff Creative 2 the top tension pulls bobbin thread up too much. I changed toe tension on top but it still does the same thing. How can this be fixed?
Suggest you do rethreading ,then test the stitches on straight stitch. If top stitches is loose you have to reduce the upper thread tension, if the bottom stitches is loose you have to increase the upper thread tension. Adjust accordingly till you can get a perfect straight stitch. If okay then you can continue your embroidery work.
Oct 31, 2013 | Sewing Machines
Over locker loopy bottom stitch
Loopy on bottom means the top tensions need to be adjusted. "All on 3 means nothing" These are tension knobs and are not required to be on the same number.
In the mean time rethread the machine with a different color on each spool This will help you determine which thread is the offender. sew the same type of material this thread set up... tighten the corresponding tension dial. Once you get a good stitch, Lift the food, cut all the threads near the spools and tie off new thread/spools and pull the thread through to the needle. Once it is all threaded again test your stitch with the same fabric again.
Oct 02, 2013 | Sewing Machines
I have a Singer
Which stitch are you using?
To check thread tension for straight stitches, use different colors of thread in your top thread and bobbin. If the top thread shows on the bottom of the fabric, turn the dial counter-clockwise (towards a lower number). If the bottom thread shows on the top, turn the dial clockwise. Do not adjust the tension too much (for example, go from 2 to 2.5 if increasing the tension) at a time; test another set of stitches. Alternatively, you can adjust the bobbin tension in the reverse directions. However, it's very easy to damage the set screw in the bobbin case so do this as a last resort. Since this is a vertical bobbin case, put the bobbin in and hold onto the thread. If the thread moves when you dangle the bobbin case, tighten the screw. Loosen the screw if the thread doesn't pull out of the bobbin when you hold the unit.
For zig-zag decorative stitches lower the tension until the puckering stops. Usually the top thread will show on the bottom of the fabric.
If the tension is not changing when you turn the dial, make sure that the presser foot is down. The sewing machine may need repair. The tension mechanism depends on a spring and that can break. See the Singer site for a parts breakdown and contact your Singer dealer for the parts.
If the top and bottom fabric are not moving at the same rate, you can get a different type of puckering. You may want to get an even feed foot if there are several layers of fabric.
The manual for the 3116 is available from Singer: http://www.singerco.com/uploads/download/438_3116.pdf .
I hope this helps.
Dec 08, 2011 | Singer 3116 Simple
I have a Viking/Lisa Model. I am having trouble with my tension and I am not sure if it is the top or bottom. My bobbin thread is all of the sudden too loose.
I just bought a Viking Lisa, and also had to adjust the tension. Use the manual to make sure you've threaded the machine correctly and put the bobbin in correctly. (I wasn't getting the bobbin thread the way it needed to be.) Then gradually increase the tension on the dial inside the top cover, checking the bobbin stitches every two inches, ending up on about 4 1/2. If this doesn't take care of the problem completely, gradually increase the side tension dial, and between adjustments on both dials, you should end up where the stitches look good. Also make sure to use cotton thread; mine doesn't like polyester thread. :o)
Aug 20, 2011 | Husqvarna Sewing Machines
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
Inherited old kenmore 10 sewing machine. it is clean and have no problem threading etc. but believe tension and settings are off because back of stiching is pulled and "loopy" what are the correct...
It sounds like your upper tension is too loose. A good place to start adjusting is at the number three on your tension dial, but you need to pay attention to how the stitches look rather than what the number on the dial is. I wrote a Tip on Adjusting Tension. Take a look at that and see if it helps.
Robbie
Aug 01, 2010 | Kenmore 744-08BH Mechanical Sewing Machine
Can't adjust the tension on old singer!
increase top thread tension slowly till u get similar stitches on both sides
Nov 03, 2009 | Singer Sewing Machines
Seting the bobbin tension on brother xl-5600
loopy underside means upper tension and or threading is wrong
Jul 02, 2009 | Sewing Machines
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
