Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
No spund there is no hear sound in system when use cd or save items
  • Anonymous Nov 13, 2008
    no sound at all i dont know if it is sound card problem or what
    Scholar:
  • 126 Answers
Hello.
Use the control panel, choose sounds and audio devices, select the audio tab and make sure the default sound card is Soundblaster and not defaulting to the on board audio.
Posted on Nov 11, 2008
Can I connect turntable with magnetic cartridge to Sony mhc gnz 9d music system.
If the unit has a left and right jack socket for a CD or tape then the answer is yes. You will need a Magnetic Cartridge Preamp to hear the sound though. Even if the socket is in use for one of the others, you can fit a switching box to switch between (say) the CD and record deck.
Both of the items will be found fairly cheap on Amazon.
Feb 11, 2016 | Sony Audio Players & Recorders
I have a new lg window air conditioner that is buzzing loudly when the compressor turns on. as soon as the compressor shuts off it stops buzzing. the buzzing noise also sounds like a playing card attached...
sounds as though the contactor is not pulling in tightly. but it also spunds as though the fan or fans might be hitting some thing . check them out shut the unit down and spin the fans and see if you hear something. if not then it could well be a contator .. But as I think a bit more could be lose fan, or compressor is not setting on it isloator bushings .
Jul 18, 2011 | LG Heating & Cooling
We have just bought a 2004 Vogue Caravan with a CD/DVD player...Philips...but there are no instructions..it is wired to a system that players music in all areas of the caravan. Can you help please.
Might be connected to the actual stereo as an auxiliary item so the caravan stereo may have to be turned on and set to auxiliary in order to hear the surround sound.
Mar 02, 2011 | Philips Audio Players & Recorders
Subwoofer not working.... JVC surround sound system 778V Subwoofer Part Number SP-PW37-SUB I hear a hum coming from unit so there's power going to it. I hear weak bass thumps with volume turned all the way...
A connectivity check could provide the solution, notice any wrong wire connections on device or any other devices requiring interconnection. The woofer would perform properly when the connections that provide current for woofing are approapiate
important notes
1. Trace the connection from Recorder or sound output to the woofer device
2. The wiring connections should be sound and video ouput into sound and video output into woofer.
3. The connections if any problems would be located at the stereo recorder or device producing the spund and video. Check the connections of wires on the recorder device ensuring rewiriing
4. finally, adjust the equalisers if any the buttoms could have been disbled by master switch hindering full blaster boost sound.
Dec 05, 2010 | JVC RX-778V
Dear Sir How to play back a movie which I saw before from 2 months & I do not have the cd . If it was saved in the dvd memory , how can I see it again .
DVD players do not save movies. It wold have to have a hard drive like a computer to do that. Only item that saves movies are called DVR's +digital video recorders. But they only record live TV brodcasts.
Oct 31, 2010 | LG HT302SD Theater System
A kind of sound is coming from left side of touchpad in my new dell inspiron 1545 laptop problem:
Hi i'm Rain.
Ok there are only 3 sounds you will here from your computer laptop.
  1. You will hear the fan running.
  2. You will hear the HardDrive running.
  3. You will hear a CD-rom drive running. Wheather its a DVD or CD-RW.
You will need to turn it over and listen from the bottom.If there is venting then more than likely its the fan.
If its where the Media drive like i mentioned {DVD/CD-rom}. Then thats your sound. If the sound is coming from an area that you can't visually see something that it could be.
Then its your hard drive. To resolve the problem you will need to first locate and name the item that is making the sound. Follow the steps i have given you and locate the source of the sound.
Nov 22, 2009 | Dell Inspiron 1545 Notebook
Sound problems
panasonic sa th-440 f61
Aug 18, 2009 | Venturer STS152 System
Panasonic home theater sound system SC-HT720 won't read or play dvds or cds
mine does the same.the display flashes "prog" and --:-- on cd's,dvd's and even the cleaning disk it almost sounds like it isn't getting enough power to spin the disk.
Jun 23, 2008 | Panasonic Home Theater System System
Whirlpool washer machine will not spin when the rinse cycle is activated, I hear the switch moving as soon as it starts to move it cuts out...
spund slike a lid switc issue, try opening and closing the lid a few times and as you do listen for a distinctive "click " noise rigth before the lid closes, if you dont hear tha tthe machine is not recognizeing that the lid is down as for safety reasons will not advance to drain/ spin mode. if this is the case youlkl need to replace the lid switch assy
Apr 02, 2008 | Washing Machines
Cannot burn dvd
Downlaod a Free CD\DVD Burner Software here >> http://infrarecorder.sourceforge.net/?page_id=5 Hope this helps ======================= If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | LG (GWA4161B) DVD±RW Dual Layer...
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
21 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
