Question about Boating
Auto helm Raymarine ST 1000+ failure. Where having it fixed?
Brand new bought over net from raymarine installed in a 24' one ton sailboat, worked a few hours in a very light sea sailing conditions and stopped.
Went "crazy" and won't steer the boat properly anymore. Has no guarantee overseas selling.
Where to have it fixed?
Thank you.
Marco Wildt
Brazil
  • Anonymous Dec 15, 2008
    I once experienced the pilot going crazy - steering opposite to the way it was supposed to. There is a setting that you can program in, to REVERSE the "sense" of the pilot. If this has been accidentally adjusted, it will cause it to misbehave. I adjusted it once, and all was good. I haven't got he manual with me, but read it, and make the adjustment - should take less than 5 minutes when you have the instructions. I hope that this is all that's wrong with it.
5 Suggested Answers
  • 5 Answers
SOURCE: Raymarine St 4000 Wheel Drive
i had face with similar trouble
I went to RayMarine Web site and got an ecopy of the manual. Inside there is a 3D Blow up of the inner workings of the Auto Pilot. There are a couple of shear pins inside on the clutch lever. It shows you how to disassemble the auto and replace the shear pins. Total cost was $0.20. It works GREAT now. No more problems. I was also was able to give the inner working a good cleaning and lube. I have a soft copy of the manual if you need it
Posted on Jul 24, 2008
ginko
  • 19396 Answers
SOURCE: Raymarine Ray 240 usa model
You cannot just reprogram your Raymarine to european standard.
This radio has been built and is licenced for using with USA frequency, in Europe his use will be limited to lower bands with no modification.
To be fully adapted to higher bands, the radio must be taken apart, and you need to bridge a contact on the main board.
The use of the radio after modifacion won't be legal in Europe.
Posted on Oct 03, 2008
TechnoMarine
  • 132 Answers
SOURCE: sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Posted on Jan 26, 2010
SOURCE: Raymarine L365 Fishfinder not registering data, it just flashes
Got a brand new one in box - let me know if interested..
mriley20@comcast.net
Posted on May 28, 2010
Raymarine 4000 + autopilot. I immediately get an RG Fail message when I engage the autopilot on my Catalina 320 Sailboat.
I am not familiar with your particular model autopilot, but I do know that Raymarine autopilots can be fussy. All must have a compatible gps feeding it, of course. All must have a rudder angle indicator if your auto pilot connects to the wheel or rudder instead of directly to the tiller.
Aug 25, 2017 | Raymarine Boating
How do I calibrate my raymarine st2000+ auto helm
Hi David.
A little late, but the information you require can be found here:
http://www.raymarine.com/view/?id=346
Hope it helps someone else out.
-Steve
Raymarine ST1000 ST2000 Tiller Pilots
Aug 20, 2017 | Raymarine Boating
St4000 auto pilot makes 180 degree turn for no good reasonn
It has been a while since I set up my auto pilot, but Raymarine has a very good set of on-line manuals and it would be a good idea to go through the setup procedure again. There is a sensitivity setting that adjusts the responsiveness of the AP in relation to changes in the helm. If it is set too sensitive, the AP will make big changes when the helm slightly moves.
Jan 09, 2014 | Raymarine Boating
Raymarine st 1000 displays 1000 (flashing and beeps) and the actuating rod will not move
Have the same problem, sick and tired of it. It is 18 month old, had repaired once 2 months ago by raymarine, some soldered joints came undone on the board, not working again! Used it 4 times since new out of probably 20 attempts. Every time I try to use some new problem raises. Possibly just my luck. Just ordered a new Navico st 32 heard it is better unit.
Jun 10, 2012 | Raymarine St1000 Plus Tiller Pilot
My Ray Marine ST 1000 auto tiller pilot started setting stuck, but not consistantly. the shaft just vibrates in some spots but does not move. what could be the probable cause?
the worm gear that is inside the unit may need to lubricated,, remove the bottom case and lubricate gears and shaft with a teflon or silicone based lube. also on my sailboat when this happened I found that I needed to re-calibrate the unit - take the boat out into a very calm and open water and ' spin the boat ' in CAL mode ( this will re-orientate the internal compass ).
have fun on the water and have a great night,
c...
Jan 06, 2011 | Raymarine St1000 Plus Tiller Pilot
My Raymarine ST6001+ says no signal. All other instuments are getting good GPS signal. I have have changed compass but nothing changed. I have a Course Computer 400 as the main autopilot controller. Can...
if the ST 6001 shows "no data" and alarms, the course computer is most likely bad. Control head failure is very uncommon, hower you should look at the brain box (T400) and move the control head to the other seatalk terminal (there are two) you may have just one failed SeaTalk port and can use it as is, otherwise, Raymarine will still fix (this week) 847-746-0100
Jul 11, 2009 | Raymarine St60 Plus Package, Includes...
ST6000 autopilot kicks out
I have exactly the same problem, It is very unpleasant, all the time we have to be close from the helm. if you founded the solution, I am very interrested. I will try some test. If I find something, I will post it.
Jun 10, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Jul 24, 2008 | Raymarine St 4000 Wheel Drive E12093
Boating Logo
243 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
