Will not connect to wifi after defrag
Click the Startbutton, access the All Programs ' Accessories ' System Tools menu, and selectSystem Restore. Because you're running in Safe mode, the only option on theopening screen of the System Restore
wizard is Restore My Computer To AnEarlier Time, and it's selected by default, so just click Next. Then, followalong with
the wizard to select a restore point and begin the restoration procedure.
Let me know if it helps you.
Use system utility tool like RegInOut to optimize your internet ,fix registry and windows errors which causing this problem
SOURCE: my lenovo sl500 can't connect to internet
you will have to open up your network connections click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps
How do I do a System restore? I tried the instructions I found online about pressing Alt and F10 but nothing happened.
