Question about Compaq Presario 1626 Cooling Fan Case Cooling Fan
TOYOTA CAMRY 2001, WHEN SHOULD THE FANS SPIN?
THE TWO FANS AGAINST THE RADIATOR ARE NOT SPINNING WHEN THE CAR IS RUNNING, ONLY SPIN WHEN THE A/C TURNED ON, ARE THEY WORKING GOOD? WHY THE RADIATOR GETTING HOT WHEN THE CAR IS RUNNING? AND SMELL THE BAD ANTIFREEZE, IS FAN PROBLEM OR RADIATOR?
    Genius:
  • 1,605 Answers
When the car is running, there is enough air to cool the radiator, however, when when the AC kick on, the radiator absorb more of the heat from the AC coil. there by require more cooling. the 2 fan are there for that purpose.
as far as the smell of antifreeze, you nee to check all of the cooling hoses, in the engine compartment and under the dash. sound like there is a small leak some place.
Posted on Nov 12, 2008
  • jaybee Jun 09, 2012
    The radiator was changed. when the car is turned on the cooling fan spins even while the ac is not turned on
My 91 toyota Camery 4 cil man transmission seems to be running hot. I was going to put water in it and it had water but I noticed the radiator fan was not spining. will this make my car to over heat
yes your car will be over heat, just go to junk yard and open thermorstar sensor of another car to replace the old one that is cheap than you buy a new one ok!
May 30, 2014 | 1991 Toyota Camry
Gets hot and runs very rough when idling as if its about to stall, cools down as I drive.
Check that the cooling fan is working of if you have a viscous fan hub check that it is operational. Electric fans should be working at around 80 degrees C and just because the viscous fan is spinning doesn't mean that it is driving to pass enough air through the radiator. The statement "it cools down when I drive" is a clear indicator that there is no air passing through the radiator at idle and by driving- the air is being forced through the radiator so it is cooling down
Sep 06, 2013 | 1995 Toyota Camry
My 2000 camry engine shakes when idling
my 2000 camry also shakes when idling. Looks like the radiator fan is culprit, but havent had time to change out yet. looks like old blades on fan broke off making it unbalanced when spinning to cool off causing excessive shaking. When driving its cool enough where that particular fan motor does not need to spin, therefore no shaking. possible solution is replace the fan that is wobbling.
Nov 27, 2011 | 2000 Toyota Camry
I have a 2001 camry that has started overheating. The two radiator fans are not turning. The blades spin by hand but are not turning on even when the ac is on. I was thinking to check the thermostat, water...
Check the ECT (engine coolant temperature) sensor. Both the fans will ground through this sensor. If it is failed, the fans will not come on no matter how warm the engine.
Jan 29, 2011 | 2001 Toyota Camry
Why does my 1992 toyota camry run hot and radiator fan runs slowly
I would strongly suggest you replace the fan as its probably worn out and this is why its spinning slowly,thus why your car is getting hot,its fairly common for electric fans to slow down with age.You need to be careful that you dont drive the car till you fix it as you could overheat it and blow a head gasket!!
Nov 15, 2009 | 1992 Toyota Camry V6
Not-too-loud roar sounding
could be a wheel bearing. get the car up where you can spin the wheel, now grab the strut spring with your hand and spin the wheel. you will be able to feel "roughness" on the wheel that has a bad bearing.
Oct 13, 2009 | 2001 Toyota Camry
Where is the radiator plug on a 1995 Toyota Camry?
Driver side, white plug under the radiator, bottom side. Spin it out and let the coolant flow baby!!
Oct 12, 2009 | 1998 Toyota Camry
1993 Toyota Camry V6: Coolant Overheating Problem.
how do u change the water pump in a 1993 toyota camry v6 engine?
Oct 05, 2009 | 1993 Toyota Camry V6
1991 toyota camry. It has a new radiator and cap,
the a/c when running creates a lot of extra heat and needs second fan, if second fan is not working right this will cause overheating, if fan is creating a load noise it is likely bearing is bad and will not spin as fast as it should not cooling. also check that fan it not hitting anything if you describe loud noise i can give better idea
Jul 09, 2009 | 1991 Toyota Camry
TOW FANS AGAINST THE RADIATOR, TOYOTA CAMRY 2001 4 CYL
yes, they are both radiator fan. dependent on the temperture of the outside air and the cooling temperure on control panel. the fan will kick on when the temperture cross over the preset- set on the computer. so, either fan on, no fan, fan is runing when the car is runing or not, is not a porblem.
the porblem occures when the fan stops, and the temperture is over 100 degree outside.
Nov 11, 2008 | Compaq Presario 1626 Cooling Fan Case...
Compaq Presario 1626 Cooling Fan Case Cooling Fan Logo
698 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
