Question about Canon PowerShot G9 Digital Camera
Canon g9 does not generate folders on sd card
When connected by usb to computer, I expected to see pictures/videos to be in folders as I have experienced with my ixsus, what I do get is pictures/videos saved in disconcertingly no particular order, please shed some light, thank you in advance
I have yet to try it- step 1: save all photos and videos on another media
step 2:format the sd card card.
I don't know if format was corrupted but hopefully it helps fix the problem
Posted on Nov 15, 2008
How can I extract the pictures from the camera memory of my Canon 550D?
You can remove the SD memory card from the Canon camers and insert the SD memory card into an USB memory card reader. Connect the USB memory card reader into the USB port of the working computer. The computer will see this card reader as an external memory device, click on this device and open the folder that contains the photos and you can then copy the photos to your computer.
Jan 27, 2012 | Cameras
Jan 27, 2012 | Canon EOS 550D Rebel T2i Digital Camera
In pictures format where does the sd card go for the tmobile htc G1 phone
Hi Elizabeth617,
Here's how you access the pictures from your SD card:
  • Connect your G1 to your computer via USB
  • Pull down the notification menu and select "USB connected: Select to copy files to/from your computer."
  • "Turn on USB storage"
  • Now open your phone in a folder on your computer
  • You will see a folder that says DCIM (This is where your pictures are stored)
  • Open DCIM and view the pictures in the folder Camera
Mar 05, 2011 | HTC G1
Canon g9 communication error
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 27, 2010 | Canon PowerShot G9 Digital Camera
SD card not recognized. Card has pictures from my Canon camera. Attempting to put the pictures from the card to my sister's Compaq Presario SR2050NX Desktop. I put it in the SD drive and nothing...
The driver for the SD card slot may not be installed.
The other option is to insert your SD card into a USB card reader and then connect it to the USB port on the computer. This computer will see this as an external USB storage device and then you can copy and paste the images into the computer.
Oct 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
I have a Canon G9, and have lost the instruction manual. Does anyone know how I can download a copy? Also, I am trying to upload my photos, can anyone help? Thanks
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_pro_series/powershot_g9#DriversAndSoftware
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Sep 19, 2010 | Canon PowerShot G9 Digital Camera
Canon sd card IXUS 97015
The best way to download pictures and videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures and videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo/video cataloging program.
Jun 06, 2010 | Canon PowerShot SD890 IS / IXUS 970 IS...
My netbook screen resolution is no good for canon instal disk
You didn't provide what netbook you got, but most netbooks today got built in SD-card readers. If your netbook does, the best solution is to remove the card from the camera and insert it into the netbooks card reader. The Canon G9 supports SD-cards, as well as SDHC, MMC, MMCplus and HC MMCplus compatible cards. I suggest using a SD or SDHC card.
You will not need to install canon software to access your pictures if you use the card reader, you will be able to access and copy/move them from the memory card in explorer (or equalent if you use Linux on your netbook). Also, it's a much faster way to move pictures from the camera to the computer, because the card reader interface is a lot faster than the USB interface to the camera.
If your netbook does not have an internal card reader, you could buy a SD card with built in USB, such as this one: http://www.cdrdvdrmedia.com/ultra-sd2-card-2gb-sandisk.html This SD card behaves like a normal memory card in your camera, but plugs directly to an empty USB port on your netbook. The card will be accessable as any removable storage, in Explorer (or equalent if you use Linux).
A third solution would be to get a cheap USB 2.0 card reader. Almost any cheap USB 2.0 accepts SD cards, and would be a lot faster than connecting the camera to the netbook with a USB cable.
I hope this help you!
/Chris
Jan 19, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
RAW images won't upload
Are you using the camera to upload the photos? I recommend that you get a SDHC reader(USB) and copy the files off of the SD card onto your harddrive. it is a common problem that RAW images cannot be read by windows or certain programs. Photoshop CS3 and later are able to read and open the RAW images from this camera if your "camera raw" portion of adobe is current. it is good practice anyway to load your photos directly from the SD card. I had a G9 since it first came out and now i have a G10--i have never even attempted to upload from the camera. don't let this discourage you from shooting RAW because it is the primary reason in my opinion for owning a G9 or G10. Let me know if this does not answer your problem...dj
Jan 17, 2009 | Canon PowerShot G9 Digital Camera
Folder missing from SD card
Transfer the folder to your computer, along with any other pictures you want to save. To do this use a card reader, not the camera. Then click and drag the folder onto your desktop. After you will format the card using your camera (press menu then under the setup tab [yellow colored]) - this will delete all the pictures on your card so make sure they transfered onto your computer. Take a random picture on the camera to generate a new folder. If you want to put the pictures back onto the card so you can view them with the camera (not necessary), you should put the card back into the card reader, then open the dcim folder. you will see a folder which says Canon###, copy that name and make sure it matches the name of the folder you previously copied onto your desktop. click and drag the folder back onto the memory card to replace the existing folder in there (the random picture you took will be over written, so if you liked it transfer it first). That should have covered it...i know i made this very wordy, sorry, but i'm used to explaining these things to my parents who don't even know how to turn on their camera.
Jan 28, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot G9 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
