Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
The hose kinks up
I start using my animal Dyson and the hose kinks up. When that happens the motor goes into overdrive and I have to turn it off and back on. Is there a better hose I can get.
    Scholar:
  • 120 Answers
Hello annfromnc228, What i would suggest trying is either extending the cord only to which you need or keeping the cord tense and firm so the hose cann kink up. If you are looking for a replacment hose i suggest "buy DC07 cyclonic vacuum hose" and you should be able to purcahse another one from there.If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Posted on Nov 11, 2008
Dyson animal pulses on and off
Hi, this happens when the PCB detects a blockage. Take the filter out and then try it. If it no longer goes for only 5 seconds then your filter needs washed. Wash the filter in your washing machine.
Apr 10, 2017 | Dyson Vacuums
Stiff hose on new Dyson Animal upright
You need to call Dyson, but bet this is as designed.
Dec 19, 2016 | Dyson Vacuums
When I tilt my Dyson DC 17 Animal upright so that I can use the hose, the vacuum powers off. As soon as I tilt it back down, it turns back on.
I'm sorry to hear you're having difficulties with your DC17. When you stand the cleaner upright, the brushbar motor is designed to shut off automatically. However, the suction motor should continue to run unless you turn it off manually with the on/off switch. If both motors seem to be shutting off when you stand the cleaner upright, it's probably best if you get in touch with us directly so we can resolve this issue for you as quickly as possible.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Dyson Online Customer Support
Jun 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
DOES THE DYSON ANIMAL HAVE A RESET BUTTON.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Most Dyson cleaners have a thermal cut-out to protect the motor from overheating in the event of a restriction to the airflow. So, if anything causes it to overheat, it will switch off. If this happens, leave the cleaner switched off for at least two hours, as it will not start again until it has cooled down.
The most common cause of a cut-out is that the cleaner has a blockage or the filter needs washing. A high room temperature may also trigger it. Before you continue vacuuming, ensure the filter is clean and there are no blockages. You can download the user guide at www.dyson.co.uk/support/. Just click on ‘Get Expert Help’ then ‘Using my Dyson product’ then ‘User Guide’.
Hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Dec 26, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
My vacuums power shut off while vacuuming
Its a good chance that your vacuum motor has either shorted out or become burnt out, this can happen after a few years of use. My only real suggestion, being what i would do in your situation, either contact dyson and try and get another motor, alternatively, contact a 2nd hand motor place, maybe a white goods store, and they may have a vacuum motor to suit as Dyson spare parts can be expensive. I hope this offers some assistance.
Nov 26, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Animal on button wont stay on.
That's the problem with dyson. They work for the first few months then start to break down. Your switch might need replacing or your cord connection is lose and causing it to short out and turn off.
Aug 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Can't use hose attachments because no suction
chech the hose for a blockage this would cause the hose to compress as you describe
Jul 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 animal bagless
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Nov 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC 14 animal bagless--unable to use wand
Hi.
Try these tests & tell me the results.
Remove the hose & wand completely from the machine it unclips at the bottom of the back.
Leave handle in full upright position & switch on do you still get the sound of something blocked ?
If yes remove the (U) shaped inspection port again at bottom back of machine now repeat last test what happens ?
Please reply with your answers.
http://dysonmanuals.llc.nu/index.htm
Chris.
May 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
113 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
