Question about Hitachi Televison & Video
Blue rainbow on hitachi 65swx20b
I know this is a convergence problem with the blue gun, I have electronics experience but no schematic or component layout. I can repair, but have no idea what the component values are for the IC or the resistors feeding it, or location. Hitachi support on this is non-existant.
MikeNJ1964
  • 398 Answers
SOURCE: Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Posted on Aug 29, 2007
  • 1694 Answers
SOURCE: Convergence Resistor Hitachi 50DX10B
2.2 ohm 1 watt...................................T.
Posted on Jan 30, 2008
easyab
  • 132 Answers
SOURCE: TV set shuts down
3.9 ohm 2W
They are parallel in circuit and measure around 2 ohms when ok. Check the fuse associated with that circuit. FD101S 3.5 A
easyab
Posted on Aug 24, 2008
  • 905 Answers
rk46 should be a 1.8 1w
Posted on Oct 30, 2008
SD Tech
  • 14553 Answers
SOURCE: i need the resistor values for RK42, RK46, RK50,
If it is 53uwx10B:
RK42 2.2 OHM 1 WATT
RK46 1.5 OHM 1 WATT
RK50 2.2 OHM 1 WATT
RK54 1.5 OHM 1 WATT
RK58 2.7 OHM 1 WATT
RK62 1.8 OHM 1 WATT
Double check the numbers on the STK chips as most of these sets use STK-392-110 OR 392-150 CHIPS-----ONLY A FEW OTHER MODELS(MOST 43 INCH USE THE 120 CHIP.)
I do this here for free so if this helps you take just a minute and give me a vote here.
If you have any questions or need help reply to this posting here--I am here to help people.
REGARDS, SD TECH
Posted on Sep 20, 2009
Testimonial: "thanks for the quick response and info. it was helpful."
Could not set blue convergence properly after it gradually drifting off horizontally. Replaced convergence chips with repair kit from tvrepairkits.com. Tested all resistors and they test good, within 5%...
U used every components,that came with that kit?Grounding ur self.Used a low wattage soldering iron resoldering the convergence ICS again,no matter what the resistors are in torrence or not replaced all of the resistors,still have the same problems.The 2 convergence ICS got to much heat and stastic ectricity charges it it shorted and kill the 2 convergnce ICs.
Dec 19, 2010 | Hitachi 53UWX10B 53" Rear Projection...
How can i manually adjust the convergence on 60ux58k hitatchi
In my experience, the convergeance is set up using the test mode and then is stored in an EEPROM. If the convergeance has gone out of tollerence a vast amount, it is unlikely that the EEPROM has lost its data and more likely there is a bad connection on a component or indeed a failed driver transistor or I/C.
The only thing you can do by moving the guns is the static convergeance. If that is the problem, slacken off the fixings and adjust the blue, leaving a cover on the red gun so you only see green and blue. Whwen that is satisfactory, cover the blue and uncover the red doing the same. That is all you can do without the test mode setting.
Hope that helps and mind your eyes, it is bright!
Oct 16, 2010 | Hitachi 60UX58K 61 in. Rear Projection...
Hitachi projection TV - video is in 3d rainbow
This sounds like a convergence circuit problem. Your set has two convergence IC chips (integrated circuit). One is for the red CRT, the other is for the blue CRT. This is a common issue with projection TVs. It is not a difficult repair if you have any experience with electronics and soldering. Both convergence ICs should be replaced at the same time. The part is IC (STK394-160E) and is available for around $36 or less. If you have a shop fix this they will likely charge $300-$400. If this information was helpful or if you would like to know how to do this repair in more detail post back on this thread. I would be happy to walk you through it.
Dec 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Blue and yellow outlines
Hello steveandlill,
I posted this before, however I believe it fits your problem too:
You have a convergence amplifier problem. This is a common problem inthese types of televisions. The fix for this problem is to replace thetwo convergence amplifiers in your tv. These amplifiers usually go badalong with the associated bias resistors. I would suggest that if youare going to do this yourself you should use only the manufacturerecommended replacement parts. There are many who will tell you toupgrade the amplifiers, but my experiences have told me this is moretrouble then it is worth, if you don't plan on redesigning the circuititself. So with that being said, here is the basic procedure:
1) Get a schematic for your set (to be used in parts location and alignment instruction)
2)Using the Schematic locate the STK329-xxx or STK392-xxx seriesamplifiers (They are the two large six sided components attached to alarge heat sink on the deflection board)
3) unplug the TV set
4) remove the deflection board from the TV set
5)using a soldering gun or iron with either a de-soldering pump orde-soldering braid remove the solder from the pins of the amplifiersand the associative biasing resistors.
6) remove the amplifiersfrom the heat sink and clean the heat sink off with alcohol or asolvent designed for removing the silicon paste.
7) coat the metal plate of the new amplifiers with heat sink paste and install them on to the heat sink.
8) install the associative biasing resistors
9) solder all of the components, making sure not to create solder bridges (short circuits) on the printed circuit board.
10) inspect the soldering job for bridges and cold solder joints (touching the joins up if they are cold)
11) reinstall the board to the television (reconnecting all cables removed.
12) power up the TV and perform the alignment instructions in the schematic
13) set the alignment of the TV
14) perform the magic focus setup
This should complete this task.
Now if you feel that you can not do these tasks, please consult a qualified TV technician about doing this for you.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 16, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Blue Projection Gun
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
May 14, 2008 | Hitachi 53SWX10B 53" Rear Projection...
My hitachi 65swx20b
Hi, convergence circuit has failed, unless you have electronic knowledge and soldering equipment you`ll need a tech for that one, questions? email me back, BMW Rider
Feb 26, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 50UX26B Blue ghost problem
Need convergence IC
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Rainbow circle in middle of my tv
Start bt realigning the convergence by using the auto focus switch. If this doen;t work, you may have a bad convergence chip. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 04, 2007 | Hitachi 42V710 42" Rear Projection HDTV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
