Question about Sanyo TRC-5830 Handheld Cassette Voice Recorder
A lot of background noise when playing back.
When playing back the tape there seems to be a lot of background noise. It's very hard to understand the dictation because of it.
    Problem Solver:
  • 6 Answers
The pic looks like a TRC5880? If thats the case they are naturally quite noisey. The motors vibrate too much in my opinion. Theres not much you can do with it unfortunately. Suggest a new recorder or get that one repaired.
Posted on Aug 19, 2009
I just bought a used PDM510. Most everything seems to be in working order, however, I can't seem to enter record mode or hear audio through line inputs. I'm not sure if the machine is broken or if I'm...
to hear the audio fold back in prerecording mode you will need a tape that still has a security tab in it if not put some tape over the whole or even block the hole up
supply the tape unit with a good signal and then hold down the pause button and press the record and play button at the same time. you will then be able to monitor the sound you are about to record. use headphones as this to stops background noise in your ears and allows you to focus on the sound, "its another world inside your cans" adjust the input level until just peaking into the red. when you are ready to record leave the record button alone and the stop button and the play button just release the pause button and away you go. to stop press stop to stop recording say to cut out an advert or something just press pause.
Apr 08, 2011 | Marantz PMD510 Single Cassette Deck
Static noise when playing back recording, sounds like the wind
This camera has a single Mic - make sure your finger isn't over it though -- try making a recording in a closed room - no wind noise - is there still static ??
Go through settings and see what choices there are -- like outdoor , indoor . close to subject etc.
My CAM had a close up and background button - which was a sensitivity setting - and the background setting picked up EVERY sound from miles around and filled the tape with noise. The close up setting only picked up sound from bout 2 - 3 meters.
Do you also have an external plug for a Mic ? this would also check whether it's the camera mic or recording that is at fault ??
Ray
Mar 07, 2011 | Samsung SC-X105L Memory Card Camcorder
Dragon naturally speaking 11 is slower and less accurate than it was. Sound playback of dictated text is slow and distorted. Have redone mic checks and training but problem remains. Am thinking I should...
It could very well be your microphone. The program needs to understand what you're saying and your microphone is crucial to that. If there's a lot of background noise or if the quality of your microphone is poor, you can check this by recording your voice and playing it back.
Jan 24, 2011 | Nuance Communications Dragon...
Seems to be a noisy fan on mb4210 combo
Could very well be the fan. The motors can cause interference. There may be a solution to get rid of the noise. Some copper shielding tape may help. You could rule out it being a microphonic preamp tube by turning the amp on as normal and tapping the tubes with something non-conductive. If you hear the tapping noise coming thru the speakers while doing this to a particular tube, replace it. With power tubes, the tops of them turn white on the top when they become microphonic, along with plenty background noise.
Apr 18, 2009 | Marshall Music
Blocks of noise
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Jul 10, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Tape plays too fast on slowest setting
The tapes may have been recorded at 1/2 speed or 1/4 speed so they are not playable on this model.
May 16, 2008 | Panasonic RR-830 Desktop Cassette...
I HAVE AUDIO RECORDINGS THAT HAVE LOTS OF BACKGROUND NOISE. WHATS THE BEST PROGRAM FOR CLEANING UP BACKGROUND NOISE, I DOWNLOADED A FREE TRIAL OF AUDITION. CAN I USE THIS PROGRAM? I HAVE NO CLUE HOW TO...
a bit late, only just saw this question. my understanding is that clearing up background noise is a specialist task. if you look at a sound wave it's really difficult to discern the main wave from additional noise. and although its possible to edit out the background of a photograph, that gets a lot trickier with a video if you follow my metaphor. the best most of us can do is open the file in a sound app (i'm on a mac so i use quicktime for this) and find the menu option to raise the volume. Now its absolutely possible that someone has come up with some new software that i haven't heard of yet of course. however good practice is; make sure you record at a good volume to start with- either do an audio test and listen back or set the levels with a headphone.
Mar 19, 2008 | Olympus VN-2100PC Digital Voice Recorder
Tascam 202 Mk111
most all twin well machines will play off one deck and record to the other.
using an outboard mic preamp will allow for less noise using the sm57. balanced mic cable with 3 pin xlr/cannon connections also reduce noise.
Nov 23, 2007 | Tascam 202MKIII Single Dual Cassette Deck
Picture is jittery and voice is garbled with noise in background
I had the same problem recently with a Panasonic PV - V4521 which has worked for years for me. I tried everything including cleaning the heads with Q-Tips and pure alcohol. Nothing improved. I tried tape head cleaners. Nothing. So finally one day, as I was unscrewing the cables, this VCR fell down onto the bottom of my foot and drew blood. Now remember, I had been trying to fix this thing for at least 10 days.
So, I dragged it up and pounded the top of the VCR until the top caved in. Then, I opened my front door and tossed it so hard against the floor of my patio that pieces went flying everywhere. I gathered up the pieces and the twisted VCR, put it in a box, and tosses it real hard into the dumpster. It's fixed. I have no more problem with it.
Jun 27, 2006 | Panasonic PV-V4021 S-VHS VCR
Sanyo TRC-5830 Handheld Cassette Voice Recorder Logo
96 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Frank Russell
Frank Russell
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
