Gateway 405ROG AC Adapter Output Polarity
I have a 406ROG but no AC adapter. I have other 19 VDC adapters but before I try one, I would like to know if the polarity is correct.
Could you measure the DC voltage at the output connector of a 405ROG adapter and tell me the polarity (+ or -) of the outer shell and the inner contact of the connector.
Thank you for any information that you provide.
  • 4,806 Answers
It doesn't matter if its + or - , make sure the pc runs on 19 volts and that the AC adapter does also, look underneath the laptop to find out if it does run on 19 volts but make sure the power jack fits the socket o the laptop before plugging it in to the mains
Posted on Nov 13, 2008
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Nov 26, 2015 | Office Equipment & Supplies
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
I have lost my AC Adapter (HDAD15W101-124) to operate my Medion life USB 2.0 colour flatbed scanner. Can I use a different adapter?
There are a few items that are important when trying to substitute an adapter. Obviously the connector must fit. After that, it is not so much the input voltage/current that is important, but rather the output/voltage/current as well as polarity. The output voltage of the adapter must match the device's requirements. The output current of the adapter must be at least as much as the device requires. Lastly, and most important, the polarity of the connector MUST MATCH, otherwise smoke and flames will occur. On round connectors, most devices have the positive terminal in the center (but mot all).
Aug 02, 2014 | Office Equipment & Supplies
My gateway e-475m g laptop will not come on or charge. i have 17.6 vdc coming out of the ac power adapter
If your power cord/charger is putting out the right amount of power then it's probably your motherboard that needs to be replaced.
Jun 27, 2012 | Amstron Gateway E-475M G Laptop AC Power...
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
What polarity is the input on the ion IED04 DIGITAL DRUM STAION BY ION. I HAD TO GET A POWER ADAPTER AND DON'T WANT TO DAMAGE UNIT. THERE IS NO PICTURE TO NOTE POLARITY.
There is NO POLARITY to worry about since you MUST use an adapter that supplies 9 volts AC at around 850ma. You CANNOT use a DC adapter with this unit and have it work. Putting a DC adapter of 9 volts on it won't damage it, it just won't work.
AC output adapters are harder to find.
Apr 14, 2011 | ION Audio iED04 Desktop Electronic Drum...
What is the polarity of the AC adapter, positive or negative, of the 15 inch Konka flat screen, model number KLC-1508U?
An AC adapter has no polarity. Are you asking what the DC output is? That would be written on the adapter itself.
Nov 23, 2009 | Konka Televison & Video
Specifications for AC Power Adapter
In is 110-120 vac and 12.0 vdc.
Hope this helps!
Visit us at http://www.nipycom.com for more help.
Dec 19, 2008 | ParkerVision SIGNALMAX WR1500...
Cpqusbfw usb hub
i have one of those hubs the ac adapter is output +5V, and current 0.2 - 2.5A, inside of connector is pos(+), outside is neg(-), input: 100 - 120 Vac and 0.45A Max
Aug 30, 2008 | Micro Innovations Compaq CPQ24USB
Computers & Internet Logo
237 people viewed this question
David Payne
David Payne
