Question about Zanussi ZBQ665 Electric Single Oven
Removal of Zanussi oven door
I have a built-in Zanussi oven ZBQ365X. Can you advise me how I remove the door so I can replace the outer door with a new one I have bought as the old one is scratched.
  • tracey_mcmul Nov 11, 2008
    Thanks for your help. When you saw "open it slightly", how do you open the hinge slightly?
    Scholar:
  • 120 Answers
Hello tracey,
Yes i may be of assistance to your dilemma, if you notice the hinges on the bottom of the door you should be able to open it slightly and gently but firmly pull upwards and outwards which will allow the door to prop off. i would suggest placing the door on either cardboard or a soft rug. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Posted on Nov 11, 2008
  • 1 more comment
  • Eeeeeeeeeekz Nov 12, 2008
    you should be able to just crack it open enough to slide your fingers into the oven. If you look really close to the bottom edges you should be able to see the hindges. Let me try to draw somehting up for ya, hold on please.
    I hope this explains things just a bit better, its what i could come up with in a few mins.
    I appoligize, it seems as though i am unable to load the immage. I could send it to your e-mail if you wish to see it. Its really simplistic and should help.
Will Details about Zanussi ZCG7901XN Cooker Top Oven Glass Door fit my ZCM7901XN oven?
I think yes, because spare part number 311407328/5 of outer glass door is the same for both oven.
Dado
Mar 03, 2015 | Zanussi Ovens
How to take the glass off the oven door to clean on zanussi zoa5525xk
usually several screws around the outer edge need removed then take the inside panel off carefully . best done on a large table
Feb 07, 2015 | Zanussi Ovens
Zanussi oven glass removal
to remove the glass door open the door and you will see two round locks each side of the door with slots just turn the slots with a screw driver and life up the door and pull when putting back push the door back in the 2 slots let it rest in and just pull a little to make sure it in and release the two round locks
Nov 06, 2011 | Zanussi ZHQ575 Electric Double Oven
FB 510 Cuisinair built in oven - how to replace door hinges and where can new hinges be obtained
Assume you have lifted the door off the oven. You may have to dismantle the door to replace the hinges. Take a hinge to an electrical appliance parts supplier to get new ones or ask stockist of this brand.
Jan 03, 2011 | Zanussi Ovens
I have a zanussi built in oven model no zbf 860b which the fan is still working but the oven is no longer heating up?? Thanks
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Aug 04, 2010 | Zanussi Ovens
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
I have spilt something down the top of the oven door. Can the glass in the door be removed to clean it?
Remove the door from the range.
Place it on a large flat surface.
Remove the screws around the edges to separate the inner and outer door parts for cleaning.
Mar 18, 2010 | Zanussi Ovens
Need English user guide for Zanussi zob 662 x
zanussi built in single oven outer glass door has just exploded any similar problems or reasons for this
Mar 29, 2009 | Zanussi ZBF360X Electric Single Oven
Zanussi Oven inside glass problem
Hi , i removed the door, and removed two small screws from the bottom of the door,you can the seperate the door into two pieces by slidng them apart,cleaned up the glass,bought a tube of heat resistant silicone and put some around the edges of the door and glass. I then replaced the glass,i left overnight to set and rebuilt the door.
Regards
Eddie
Jan 27, 2009 | Ovens
Zanussi ZBQ665 Electric Single Oven Logo
547 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
