Question about Lexmark E232 Laser Printer
Lexmark E232 photoconductor
Last week my printer's error light came on and it stopped printing. The last page it printed was a page saying I needed a new photoconductor. I purchases a lexmark photoconductor. I put it in with my toner cartridge and the light is still on and the printer will not work. I have reset the printer, tried shutting it down for a bit and turning it back one. I don't really know what else to try.
Make sure to install the new photoconductor 1st.
1) Power off the printer using the switch in the back.
2) Open the front cover.
3) Press and hold the Continue button (Big silver button with Diamond shape symbol) and power the printer On (turn the switch back to ON).
4) When you see the last light i.e. error light on solid, release the Continue button and close the front cover.
5) When you close the cover you will see all the top 3 lights on solid.
6) Press the cancel button with X symbol for 4 times very slowly till you see toner low light (i.e. second light from top) on solid.
7) Press the continue button and wait until you see the light sequence.
8) Press the cancel button and wait until you see the light sequence.
9) Finally power off the printer using the switch in the back (IMPORTANT= wait 1 minute) and power it back on to exit the configuration mode.
Posted on Feb 09, 2009
Use the management software to reset the photo conductor count. There is a cd that came with it that has a management tool. This software is how you setup and manage your printer. check the lexmark website if you have trouble I am sure there is an explanation on how to reset the count
Posted on Jan 08, 2007
SOURCE:
Lexmark E232 secon light from the top keeps blinking I think this is ink, I can print a test page and it is nice and dark and prints fine
This light sequence means that the photoconductor kit's drum is almost full and will need replacing soon. For more information on how to replace photoconductor, click on the link http://bit.ly/oD75Kw
For additional assistance, please contact Lexmark Technical support
Jul 21, 2011 | Lexmark E232 Laser Printer
I replaced my photoconductor and now my printer won't print. The toner button and ! button flash.
The photoconductor kit's drum is full and needs replacing. The printer will not print any more pages until the photoconductor kit is replaced.
Click on the link http://bit.ly/oD75Kw to see instructions on to replace photoconductor.
For further assistance, please contact Lexmark Technical Support
Jun 06, 2011 | Lexmark E232 Laser Printer
My toner cartridge was recently replaced (we use the proper cartridges, not refills) and within about 3 weeks (sooner than last time) the "toner low" light is flashing. The print quality is still perfect....
Whenever you replace the photoconductor kit, you will also need to manually reset the photoconductor page counter. Visit the Lexmark website at http://bit.ly/8YJwFU, for the instructions on how to reset the pc page count. You can also contact Lexmark technical support or your authorized service provider for additional assistance.
Sep 24, 2010 | Lexmark E250dn Laser Printer
Printer printed out error message stating that the photoconductor kit had worn out, so I ordered and installed a new one. However, the printer continues to print the same error message and nothing else....
After replacing the photoconductor kit, you will need to reset the photoconductor page count. Here's the link for instructions on how to reset the page count: http://bit.ly/agYtVo . Or simply press and hold the CANCEL button while the printer is on and the front cover open until all lights are flashing. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 27, 2010 | Lexmark E232 Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
How do I replace the photoconductor where is the menu button to reset PC CNT appears after it is replaced?
Power the printer on and get it to the Ready state. With the printer on and in the Ready state, open the front cover.
Press and hold the Cancel button until all of the lights begin flashing up and down.
Release the Cancel button and close the door. The photoconductor count should now be reset.
To confirm that the photoconductor page count has been reset, it is recommended that you print a menu settings page and check the photoconductor level. Do the following:
With the printer at the Ready status, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
Look for a section labeled Cartridge Information and locate the word Photoconductor under this heading.
Confirm that the photoconductor level reading is either OK or close to 100%.
If the reading is low, try printing 10 - 20 pages. Print the menu settings page(s) again.
Confirm that the photoconductor level reading is OK or close to 100%.
Good luck, Gerrit Jan
Oct 29, 2009 | Lexmark E232 Laser Printer
Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Jun 04, 2009 | Lexmark E232 Laser Printer
E232
I have the same problem. At least not it's printing but the lights still on. But while researching on the Lexmark Website I see that this printer has a recall. Check the website for additional details.
Sep 30, 2008 | Lexmark E232 Laser Printer
Lexmark E232 Printer prints all characters fine but leaves about an inch gray/black margin on the left side of the paper. Tried replacing the toner cartridge and it didn't help. Any suggestions?
If this model has separate toner and photoconductor then the photoconductor is at end of life and needs to be replaced. Follow the directions that come in the new photoconductor package to install and reset the PC count this is important.
Luck
Mar 07, 2008 | Lexmark E232 Laser Printer
Lexmark E232 Laser Printer Logo
2,336 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
