Question about Bosch 24 in. SHU43 Built-in Dishwasher
The dishes don't get dry enough
There seems to be some spotting and too much water left in the dishwasher after cycle is finished
Here in Colorado, you just open the dishwasher and the dry air will do the job. The real problem comes when you run it and leave ... and your dishes stay wet until you get back.
Frankly, I can't understand why Bosh does not add a small fan to run air thru the beast at the cycle completion; since dishes are hot they would dry fast. But the damned box remains hermetically sealed, unless you open it.
Posted on Nov 21, 2008
I was able to fix this by using rinse during the cycle.
Posted on Nov 15, 2008
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
Spots are left on the dishes after washing. Dishes don't look clean
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Does not seem like the dishwasher is drying like it used to. After it has gone through its entire cycle the is steam condensation on all the dishes and the inner door. Previously, at the end of cycle...
Have you run out of Rinse Aid ?
This has a large effect on drying as well as how clean the dishes come out. Rinse aid [breaks up] the water dispersion, so at the end of the final rinse, the water just falls off the dishes, takes the sediment with it. So with the heat of the final rinse, & less water left on the dishes, they dry better.
Dec 12, 2009 | Kenmore Dishwashers
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
377 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
