Question about Bunn VPR Coffee Maker
Very little water out when brewing
I purchased a Bunn VPR coffee maker off Ebay and when water heats up flow is very low. I took the tank top off and there is a black nylon tube extending down into the tank attached to the Stainless Steel Sprayhead tube....It is melted and won't allow much water to pass. Is this replaceable...looks like all I need is this black nylon tubing???
If it is, does someone have a part #...the parts manual does not show this tube in the picture.
    Scholar:
  • 120 Answers
Hello markh525, Yes the tube is replacable. I do not have the part number off the top of my head but if you were able to search google for that exact coffee maker you should be able to come across it. If you feel like doing a project then all you will need is the corect gauge tube. If you are able to take the tube to a plumbing store they should have plenty laying around. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Posted on Nov 11, 2008
  • Noel Smith Aug 28, 2011
    Did you find the part number for this Item? My VPR was not brewing at all and after reading about your maker I removed the sprayhead tube to find nothing attached other than a clear beveled bushing type of cover that only covered the sprayhead tube. Nothing goes down to the bottom of the tank. Thanks for your help!
We have a Bunn vpr pot and we empty it in the fall and restart it in the summer. How much water needs to be added and how long do we wait until the water is ready? Also once we made a pot do we just need...
The bunn VPR is a gravity brew system what you put in if the tank is full is what you will get out. So pour water in until it flows out the sprayhead, then turn machine on, when it heats up fill up a carafe with water (1.9Liters) and put in your filter with water and brew. It is a good idea to pour water in every morning to make sure tank is full especially if you are not using brewer on the weekends.
Jun 26, 2011 | Bunn VPR Coffee Maker
We need to store a Bunn VPR Series coffee pot. How do I remove the water from the tank?
try hitting 'brew' until all the water evaporates, or look for a 'leak' valve to empty it. usually on the bottom or the side near the tank.
-swish-
May 06, 2011 | Bunn VPR Coffee Maker
How do I get the BUNN VPR coffee maker to brew a pot of coffee? There are two switches; one for the lower, and one for the upper warmer. Do I first have to fill the tank ALL the way before it brews? Please...
This brewer has a 2 1/2 pot reservoir. You should NOT plug in the brewer before the reservoir has been topped off. Pour 3 pots (one at a time, every minute or so) through the screen with a pot under the filter basket. Wait until the water flows from the basket and only then is it safe to plug in the brewer. The reservoir holds HOT water until you are ready to brew and then, by pouring in a pot of cold water, you will be able to brew.
Sep 15, 2010 | Bunn VPR Coffee Maker
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
When i make coffee sometimes the water that comes out is cold or luke warm
The brewer has not had enough time to reach its operating temp (usually 7 mins after a brew cycle). If that is not hte case then the machine needs to be descaled.
Feb 18, 2010 | Bunn VPR Coffee Maker
I have a Bunn model VPR, I can fill it up with water, plug it in, no water. turn it on, no water. it gets hot. I opened it up, there is no restriction. What coulf cause this?
This is a pour over unit.
You fill the tank with water, it heats the water in the tank.
When the water in the tank is at brewing temp, the lite should go out.
To brew coffee with this system, you put a filter in the brew funnel, put coffee in the filter. Place the brew funnel in the slide tabs to hold in place. put an empty decanter on the warming plate under the brew funnel. Then take one decanter of fresh water and pour it in the top of the brewer where it says "WATER ONLY" the coffee will begin brewing immediatly.
Oct 26, 2009 | Bunn VPR-Black (33200.0002) Coffee Maker
My bunn coffee maker is just dripping when it is making coffee. Then the next time it makes it just fine.
Hello, I am wondering how long between times you are stating, as most Bunn commercial units, stay heating 24/7, and if water is not poured into the machine every couple of days, they will evaporate off water that is held in the tank. This drop in water level can cause short brewing, slow brewing, etc.. as the unit relies on a vacuum or suction to brew properly. You could also have a leaking tank gasket, or brew tube gasket, and it is seeping air into the tank, breaking the vacuum/siphon action, and then seals with water, or expansion at other times. Another cause would be scale build up, and pieces are floating in the tank blocking the flow of water, or your spray head may be clogging/clogged, which minor cleaning should take care of the sprayhead, and tube, or a major cleaning necessary for the tank.
Hope that helps, and thank you.
Mar 04, 2009 | Bunn VPR Coffee Maker
BUNN VPR
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
Jul 19, 2008 | Bunn Pour-O-Matic VPR
Bunn VPR 04276-0003
There is a thermostat underneath the top of the machine. There are a couple of little screws that you need to undo then you will see a little dial or even a little T on top of a metal box or circuit board. I recommend that you unplug the machine before opening it up. Then just turn the thermostat down - usually counter clockwise. Turn it just a little and put the top back on the machine and let it heat up.
Apr 16, 2008 | Bunn VPR Coffee Maker
Bunn VPR Coffee Maker Logo
118 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
