Question about Toshiba Satellite A60 Notebook
Toshiba Satellite A60 wont post
Hi, I have a Toshiba A60 Equium that wont start up. Currently, when powering up, the blue powerlight around the power button illuminates, I can here the dvd rw initilise but the screen stays blank and the machine does not make any other startup sounds. It does not beep, etc. I can not switch it off either and have had to remove mains power and the battery. This problem is consistent. Prior to this: -------------- The problem originated when I attempted to update the HID device driver within Windows XP Device manager, I clicked the [update driver] button but the machine froze. After 10 minutes I powered down by holding the power button. It hasn't started up since. This all started with intermittent keyboard and mousepad/trackpad problems whereby the keyboard / or mouse failed to work intermittently, requireing restarts. Please help! Thank you.
  • Byte Code Nov 08, 2006
    Hi Sandrew,
    Thank you for your response however, all of your suggestions ignore the fact that the machine fails to even initiate the POST. (Power On Self Test) and therefore the following suggestions are not implementable, your solutions, whilst welcome, depend upon sucessful POST, and operating system boot - neither of which occur.
    As stated in my first description, the screen remains blank, does not make any ohter startup sounds, and can not be turned off via the power button.
    The only way to "turn off" is to eject the battery and remove mains power.
    Even holding down the power button for 10 seconds fails to turn the machine off.
    I cannot even make any BIOS changes, because hte machine does not even get that far.
    In fact, prior to the problem, there is a mpoment at power-up when the black surface of the screen appears to "charge up" which I presume is part of the hardware starting up - but since the start of the problem described above, the screen does not even do that.
    Thank you for your suggestions, but they are not relevant to this problem from what I can see.
    Do you (or anybody else) have any other ideas / suggestions? All are welcome.
    Thank you.
  • Byte Code Nov 20, 2006
    Hi Again Sandrew,
    once again, thank you for your help.
    It definitely isn't fesible to use a Windows re-installation CD - as previously stated, the system does not go as far as POST - therefore, no opportunity to re-install the OS, but then - I do NOT believe that the OS is at fault, I believe that this is a Hardware fault.
    I think that you are right - it's a repair shop problem as I believe that either the bios / CPU / Motherboard is faulty.
Similar problem some time back and removing the battery for a while then re-inserting it did the trick.
It is worth a try.
Posted on Oct 26, 2007
    President:
  • 2,961 Answers
It may be possible to startup in safe mode(press F8 on boot up) and highlight 'Last Known Good Configuration' or highlight 'Start Windows in Safe Mode. If this gets you up try a system restore to before you updated driver or look for the system recovery folder, normally on another partition of your hard drive, that is if you didn't get a recovery cd. If you are not able to get up and running you will need your Windows Installation Disc to either repair the system or do a complete re installation by putting in cd whilst you boot up. It may also be that your HDD is damaged and thats why you can hear the cd drive powering up, looking for a system disc, as it cannot find Windows.
Posted on Nov 07, 2006
  • andrew pester
    andrew pester Nov 09, 2006
    If you cannot get started by your windows cd as last posted:
    Then your cd drive is not working either and it's a full professional repair job, as no boot system; no cd boot; no chance of a look into possible faults.
    Maybe new hardrive is the only answer, but still does'nt answer as to why you cant get into a post, only solution to that is to remove and replace bios battery if you can find it(either behind screen or ina plastic casing under keyboard or on the underside of laptop.
How do I fing toshiba A60 equium password
pull the battery out and leave it out for a few minutes and then put it back in - if you can reach the bios then reset optimum settings - if there is a windows password then reformatting will get rid of that one.
May 16, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
My Toshiba Equium laptop won't just turn on. When I press the power button it blinks for a few seconds and then turn off.
Is the power plug plugged in. Make sure its plugged in, and leave it in for 2 hrs and then try and power on.
If you need more help just post.
Feb 07, 2010 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 wont power up
It looks like some divece in your laptop dont pass POST test. Tech support from Toshiba required
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Is my toshiba equium a60 wireless
no, there is no built in wifi but you can add a wireless card.
Sep 19, 2009 | Toshiba Satellite A60 Notebook
I want to download sound driver for my toshiba equium EA60 PSA67E-00300C8J
Windows XP Driver for Equium A60:
http://support.toshiba-tro.de/tools/Satellite/sa60/win-xp/display-xp-614106430.zip
Windows 2000 Driver for Equium A60:
http://support.toshiba-tro.de/tools/Satellite/sa60/win-2k/display-win2k-614106430.zip
Generally all Toshiba drivers you will find on this website:
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_drivers_bios.jsp
PS: You should use the Toshiba graphic drivers because these drivers are especially designed for notebook usage.
Sep 15, 2009 | Computers & Internet
Upgrade memory problems
are you sure you are putting the proper ram in? don't mix and match speed and size. If you can put it back the way it was and get it to start again, go to www.crucial.com and run the scanner. It will tell you exactly what you need.
Jun 16, 2009 | Toshiba Satellite A60 Notebook
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
Toshiba Equium A200-1VO won't turn on
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Try starting it again.
Apr 22, 2008 | Toshiba Satellite A60 Notebook
Toshiba equium laptop
it seems to be some dirty thing on lens so you may buy  a dvd cleaner then clean the lens and you need to clean your disk drive every 15days intervar ok
Jan 21, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 Notebook Logo
233 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
