DVD player set to the wrong TV type and I can't see the menu
I have a PRIMA HT-8104 home theatre system. I am in Canada.
Iaccidentally switched the TV type (in Setup on the DVD player) awayfrom NTSC and now my TV set will not display the DVD player menu.
Because my TV won't show the menu, I can't change it back.
I have tried unplugging it, waiting and then plugging it back in, but it does not help.
There does not appear to be any external way to re-set to factory settings.
What can I do?
Thanks
  • masonjarz Nov 11, 2008
    nyindianmike, thank you very much! Your solution worked like a charm.
    Scholar:
  • 124 Answers
If you have a component connection, switch the yellow video cable into the component BLUE connection. You will get am image, just reset the unit or undo the setting.
Posted on Nov 11, 2008
New prima remote control needed 2111dvd
I bought a Prima dvd home theatre system,(HT-8104) , but could not get it to work about two years ago and have not got rid of it, so i do not know what to do with it as it was bought at a close out sale ,no returns, i have a remote control never used ,maybe it is compatable , ...Nick
Mar 16, 2013 | Televison & Video
Prima ht 8104
Hello
What is the problem with your Prima HT 8104?
Mar 04, 2012 | Televison & Video
My Blu-ray DVD MBFH does not work on my Blu-ray player
do you have it hooked up via hdmi to a tv that has hdmi? also make sure you set the output for the dvd/blu ray player to the correct output your using (hdmi 1 or w/e not a passthru or input) also if your using component cables you may have to go to menu on the unit and select that as your outpput get back to me let me now if this helped
Mar 17, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
No surround sound with Prima HT-TW57P DVD System
I realize this may sound silly but it could be the disc your are playing. Some DVDs are not mixed for surround sound and thoes that are produce very little sound from the rears.
Rear speakers were meant for effect, not meant to distract you from the picture.
Give this a try, get a movie playing that is 5.1 surround sound. Check that the home theatre is not set to stereo mode, if it is change the surround mode on the unit. Now that you are in the middle of an action scene disconnect the front speakers and see if there is background noise comming out of the rears.
If its still dead let me know more details about the system and I will work on a solution.
Cheers,
Jan 06, 2010 | Televison & Video
Connect external sound system to Prima tv
There is sound coming from the tv speakers though? I had the same problem with my top of the line 7 channel surround sound theatre system. Its not that there is anything wrong with the sound system but that you may need to plug the Audio cord into the external device IE: cable box. Mine works strictly for the dvd function of my system because of this.
Jun 21, 2009 | Prima CV2011 TV
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Jun 19, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Prima HT 8104 home theatre
in the 3D processing turn on the Pro Logic and the for the mode as well set it to pro logic.
it simulates 5.1 surround.
this is what I did and it's decent. Other way would be to run the system through a amp/receiver that supports 5.1 surround.
Mar 24, 2009 | Audio Players & Recorders
The audio will not play through the tv from the home theatre unit
because you do not have the dvd player hooked up to the tv, if you want it to play through the tv then you need to have the dvd player connected to the tv.
Mar 21, 2009 | Samsung HT-Z310T Theater System
Same prob i also have the same problem my dvd is connected via scart to my tv i have nothing on my tv to connect the system to i have red and white on my dvd and also video so will this system work
i have just bought a DURABRAND SA51AR home theatre system, to go with my DURABRAND 2127N tv. and DURABRAND CG5660-M freeview set top box. i have connected all my output leads obviously the speaker ones. but my input i have only one red yellow white jack on my tv and three sets of red and white jack leads with home theatre system. cant get no sound no matter how many times iv swapped the input leads ... any idea s whats going wrong :oS :(
Apr 30, 2008 | Durabrand HT-3915 System
Televison & Video Logo
187 people viewed this question
Top Televison & Video Experts
