Question about Teac PD-H300 CD Player
PD-H300 not recognising CD's
The CD player in my reference 300 system has stopped recognising CD's. When you put a CD into the system it tries to read it but doesn't pick up anything and the CD tray opens again. Frustratingly occasionally out of the blue a CD will be read correctly and the player works fine! Will cleaning the lens help in this case? Many thanks
  • 1 more comment
  • Lancem Dec 22, 2007
    My cd changer is saying no disc found when there is a disc in the slot. Just keeps saying no disc going to the next slot saying no disc.
  • Blueboat Dec 23, 2007
    Yes , I have exactly the same problem with my TEAC 300 cd player.
    I tried a lens cleaner disc (Maxell) but still no luck.
    As stated , every now and then it works perfectly
  • Anonymous Jan 08, 2008
    cd players displays err
Firstly I'm an amateur so this is based on my opinions and all advice is without warranty. I had the same problem, no disk, just a clicking sound and no disc rotation. I removed the cover and attempted to clean the lens. This did work a little. The solution was a new laser unit a ? Sony ks-210a this unit was bought cheaply off eBay for eight pounds.
The spring that keeps the lens in position is made of plastic and fails with age, the laser ? lens cannot position in order to read the disc and if it can't read the disc it thinks there's no disk and that's why it doesn't spin it up.
Ok so now we know the reason let's change the part. Remove the case after disconnecting the unit from the mains leaving it for twenty minutes to ? discharge any capacitors. You will see the tray that holds the cd. Around the edge are four screws which engage with the metal case. Remove these and lift the rear end first to remove unit taking care to disconnect the four electrical connectors two on the side of the board and two on the rear of the laser pickup( red and White) note the position of the wires. Turn the removed unit upside down and you will see four springs held by small Phillips head screws. Remove these. The laser head is held by a sliding bar. Release this by moving the retaining clip to the side and withdraw the bar to remove the laser head. You may have to release the White cog which engages with the grooved slide on the laser head, to do this just pinch the rear of the shaft of the cog and withdraw it. Now for the new laser head, these are sensitive to static, so earth yourself ? by touching something metal ie, door handle to discharge any static. Position the new head and replace the slide bar, screw the four Phillips screws back down. Your almost done. The new unit has an anti static solder blob which protects the laser unit in transit, this has to be removed. You will find it behind the red and White connectors on the head at the bottom left hand corner of the laser head board. Carefully remove this with a soldering iron. Now fully reassemble. You should find for eight pounds or less you have a new cd player!?
Sent from my iPhone
Posted on Mar 07, 2011
On my PD-H3000 the problem varied, sometimes it would start the motor, sometimes not. Sometimes it would operate the lens transit motor, sometimes not. I checked these multi way conectors - there are 3. One is a ribbon cable header connection - very delicate. I found that reseating all the connecters did the trick. BE CAREFUL not to strain soldered joints etc. Ease the connectors in and out with infinite care!
Posted on Jul 20, 2010
I have an old pioneer cd multi pdc-p30c. i need instructions to operate. problems with playing cd
Posted on May 13, 2008
Had the same problem with a Nakamichi. It was caused by an old / inefficient belt that was supposed to drive the laser up7down to search the disk. The motor and all gears were fine, only problem was that the belt 'slipped' and did not drive the system as planned. Everything else was fine. Replaced the belt with a rubber band to verify it was the problem and all worked fine. By the way - original Nakamichi parts are close to impossible to get. Don't buy Nakamichi if you live in Europe or the US
Posted on Feb 19, 2008
FOLLOWING ON FROM MY REPORTED PROBLEM I WAS DETERMINED TO FIX IT.
I REMOVED THE OUTER CASE ( AFTER UNPLUGGING THE UNIT ) AND WET CLEANED THE LENS WITH METHATED SPIRIT. THAT CURED THE DISC RECOGNITION PROBLEM BUT THE MOTOR WAS NOT STARTING EVERY TIME.
VERY CAREFULLY I MANAGED TO GET A LITTLE WD40 ON THE MOTOR SHAFT AND HEY PRESTO IT NOW WORKS OK EVERY TIME.
HOPE THIS HELPS SOMEONE.
Posted on Jan 10, 2008
Who ever said that is WRONG. Do not do that . Dust it maybe but no... what happens is you need to get good qualities when burning songs. Sony's are great and u need to burn those cds at a low speed 8x or even 1x. CD players that are less than 200 bucks are not worth buying. trust me. Reason for burning them slowly is so that your cd player can be able to read. the slower u burn it the deeper the burn. Also quaulity of blank cds counts. get quality trust me.
Posted on Oct 29, 2007
    Problem Solver:
  • 9 Answers
Yes, most probably cleaning the lens will be helpfull. Dip the cotton part of a cotton stick in some ethyl alcohol and with this cotton wipe very softly over the lens. Preferably use some lint-free cotton or eventually lint free tissue,which you can buy in a photogaphy retail shop. Note, if you're smoker you might to repeat this in the future. Keeping CD's clean of course is recommandable. Lasers are not eternal; their power output will go down slightly after a "long" service; cleaning won't help in that case.
Posted on Nov 07, 2006
4 Suggested Answers
SOURCE:
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
localwonder
  • 6784 Answers
SOURCE: Teac PD-1200 Compact Multi Disc Player
This is a faulty loading motor. you will need to replace the entire optical lens assembly in this case. the motor is part of the assembly.
Posted on May 29, 2009
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
H300 mk 111 hi-fi system. Why is the remote sensor on cd player (PD-H300 mk 111) not recognised by the remote control unit (RC-1091)?
You have this backwards. The remote control sends signals to the sensor on the CD player. It is possible that the remote batteries need replacement or that the remote has a malfunction.
Jul 24, 2015 | Teac PD-H300 CD Player
Player keeps skipping over cd missing some of the music.
get a cd cleaner and use it,then wash your cd and dry it
Apr 11, 2015 | Teac PD-H300 CD Player
Disc error appears when cd is loaded. Have tried with different cds
If the disc loads into it properly, the fault is with its laser pickup unit itself.
Apr 29, 2012 | Teac PD-H300 CD Player
When i load a cd it wont play and then rejects the disc. if i turn the unit on it's side it will recognise the disc, and play, and if i turn it back it continues to play. when i eject the disc and put in...
This sounds like a loose solder joint or something else that is out of place, but clicks back in place when you move the player. Should be easy to spot. Might just need re-soldering. Have a look inside and see what you can see. Try turning it on the side. It doesn't need to be on, but watch carefully what moves!
Feb 28, 2018 | Teac PD-H300 CD Player
Put a cd in playey, plays for around 20 seconds stops playing then restarts playing and keeps doing the same
sounds like the laser tracks might need regreased to me, does it also skip when playing ?
Feb 07, 2010 | Teac PD-H300 CD Player
Can I download owner manuals for PD-H300 mk3
i have found some you can pay to download but it would probably be best to email them at parts@teac.com and request a manual for your product.
Aug 07, 2009 | Teac PD-H300 CD Player
Mar 14, 2009 | Teac PD-H300 CD Player
Aug 12, 2007 | Teac PD-H300 CD Player
CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Nov 19, 2006 | Teac PD-H300 CD Player
Teac PD-H300 CD Player Logo
2,324 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
