Menu on 2 used Zenith's ''Presentation Series won't work
I have recenly aquired 2 Presentation 27" zenith's I already have another one identical to the 2. The first works great the next two have the exact same problem, 1 was manuf. in 99, the other 97. They have preset channels that work fine but I have no access to the menu of either one, either on the front panel or by remote. All I get is menu> and can't do anthing else. Is there a reset, or is something seriously wrong with them. It seems odd that both have the exact same problem, they did both come from the same school so I didn't know if it was a setting they put on there. With the remote or front pannel I can adjust volume and channel up or down, but cannot enter a channel # and go to it. On the identical unit that does function, when I change channels there is a red box on the upper right around the # on the two other units sometimes they try to do this but immediately go to a small yellow # on the left. Other than this issue they have good picture and sound. I sure appriciate your insight on this. Jim
jomaru
  • 337 Answers
SOURCE: Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Posted on Oct 02, 2006
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
  • 9 Answers
SOURCE: Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Posted on Aug 11, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
  • 159 Answers
SOURCE: Problems after convergance IC fix
try not to mix areas in the tv chasing several problems.
  1. Lets get back: i hope the tv was doing fine before to start digging into it ( was it?) Was the tv complete tested before to make sure the buttons were working all and the audio was there. I mean each part of your tv has different solutions:
Think you have an animal with several heads now:
  • the buttons in the panel (some working is good! some others can be replace and there it go all panel works)
  • audio mute (maybe no signal and automatic mute is there. or maybe really audio is damaged. Leave it at the end is another area.
  • Touch focus is the the program controlling convergence digitally talking. If the tv is not yet fix with the amplifiers then the problem still landed in another area not in the digital control.
Finally Start over! Get into de convergence and get your three tubes at least close to convergence (forget auto focus now) three screens together or almost but three rectangules with white noise. No having GUI you mean OSD (i gess) (on screen display) channels appearing when you push that button or audio level line or menu letters (several buttons have to be touch to make sure of there is not OSD.
if the tv has not white noise the screens are without convergence. you are digging in a set with maybe 5 problems the three you told me plus the other posibilities im gessing and i hope you don't have. So slow down with the repair and try step by step. bye now.
Posted on Apr 17, 2009
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
Zenith dtv converter, favorite channel button
Found the solution in the user manual. You have to go to the 'edit channel' section of the on screen menu.
Dec 30, 2008 | Zenith C27A24T 27" TV
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
How do I unlock the volume control?
Zenith Electronics Corporation is a long-time leader in electronic enterainment products.
Aug 24, 2008 | Zenith C27A24T 27" TV
Zeith 27 inches 2001
You will need a Zenith remote with a menu button
There should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlocks the auto-program (change to 0)
May 28, 2008 | Zenith C27A24T 27" TV
Need a code for my tv zenith
Zenith Product Codes
TV Mode Zenith Code 101 - VCR Mode Zenith Code 201 - Cable
Mode Zenith Code 353 - AUX Mode Zenith Code 401.
Programming Codes---
TV - 101 149 175
Apr 27, 2008 | Zenith B27A11Z 27" TV
Zenith 27 in TV
I am looking for a couple of parts for my zenith tv model # A27A11D.
fuse-1360011423A
knob array-04610578
Apr 25, 2008 | Zenith A27A11D 27" TV
2 Problems
this answer has given also to some one had the same problem.
"On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu." Good Luck
You can also get a user manual at the link below:
http://www.retrevo.com/s/Zenith-C27A24T-TVs-review-manual/id/277ag102/t/1-2/
Jan 20, 2008 | Zenith C27A24T 27" TV
No remote
heidib, if the front of the set has a menu button try going in and autoprogramming your channels, it seems odd that it won`t go above or below channel 2 which tells me none of the other channels are programmed in. Good luck
Nov 27, 2007 | Zenith C27A24T 27" TV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
