Ricoh 5510 - how do I enter service mode to reset fuser error. Have service book, but cannot make procedure work. help. I am a printer Tech.
How to fix error sc561 error on Ricoh Aficio Mp c2000
fuser fault code: If you are not a copier technician need to buy a new fuser assy and reset fault code through service mode or have tech come out and look at it.
Sep 20, 2014 | Ricoh Office Equipment & Supplies
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Purchased new fusing unit for ricoh cl3500n; installed; tried to reset computer by holding escape for 5 seconds; does not clear out error message 'replace fusing unit' ; nothing will print; can not get to...
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Jul 07, 2009 | Ricoh Aficio CL3500N Laser Printer
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Replaced fuser on LANIER SP C210SF, machine still says replace fuser
It is not recomended to enter service mode on this model if a service tech replaced the fuser they owe you to reset this fuser counter. -Carl, Ricoh tech.
Mar 20, 2009 | Brother MFC-9420CN All-In-One Laser...
How do I fix error SC552 on Ricoh 2238C?
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
In order to clear error SC542, you must perform procedure 5810.
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Ricoh service mode to reset
This is the solution from Ricoh website:
Please press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust. If after completing the procedure the error persists, please contact your service representative for support.
I'm told this works as well...
On the main board put dip switch 101-1 on and then off and then enter 97 and press the aps key. Then power cycle the printer.
Jul 09, 2008 | Ricoh Aficio CL3500N Laser Printer
132 people viewed this question
jasbo
jasbo
