Question about Intertherm Heating & Cooling
I have intertherm hot water electric baseboard electric heater model MD-7 and need to change out thermostates. What are good digital display type thermostates to use for this
SOURCE: Fan Only Won't Work
I jumped the rc and rh wires in the therostat box and now have fan only when selected.
Posted on Jul 02, 2008
  • 340 Answers
SOURCE: No water in the copper pipes in our baseboard
water is fine. Tom
Posted on Jun 18, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: as I was cutting weeds away from my outdoor ac
This wire is powered by a small transformer, and delivers low voltage to energize the colenoid that turns on the ac unit. Turn the ac on from the inside. Then check if it is getting the voltage. Usually 24V AC. If not getting the voltage, go to the attic where the evaporator assemble is and locate that small transformer. It may have shorted out. You don't have to get an exactly the same one, but get one with same rating. They are rated with input voltage, output voltage, and ampere. They are usually 800mA. The input is usually 120 volts ac and output is 24 volts ac. It should say it on the transformer itself.
Posted on Aug 15, 2009
heatman101
  • 43501 Answers
SOURCE: Intertherm electric / hydronic baseboard
There is nothing you can do if they want heat....the convection currents are what heats the rooms....hot air naturally rises and the cooler air falls to the floor... can't change nature...
heatman101
Posted on Dec 12, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: Electric baseboard heaters causing black
TSP works great and is sold in most hardware stores.
Posted on Jan 09, 2011
Intertherm baseboard heater model EBHA200024 has 240 volts but will not heat. It is on a circuit with another heater that does work. Would it possibly be the limit switch ?
That is the first thing to check. You can trace voltage to and from hi limit switch, if power is there and power applied to heating element check element. Please e careful, electricity respects no one.
Jan 07, 2018 | Intertherm Heating & Cooling
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
Intertherm electric / hydronic baseboard heaters. Tenants are complaining it's producing a smrll that's causing headaches.. I turned it on and yup it's defiently has a smell.. almost like a antifreeze...
heatman101
Dec 11, 2010 | Heating & Cooling
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
Heat
What is it that you are trying to do? Do you have a piece of hot water baseboard heater and you want to 'power' it with an electric hot water heater?
Codes aside, I don't see why it would not work. You will have to put a circulator (and a temp control device) on it to move the water.
This is not going to be a very economical heating system.
Feb 05, 2010 | Marley Electric Hydronic Baseboard Heater,...
Installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Nov 08, 2008 | Marley Electric Hydronic Baseboard Heater,...
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
108 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
