Question about HP Compaq Presario V2000 Notebook
Compaq presario m2000 pent 4 15.4trubrite screen won't power up
I bought 3 as is on e-bay looks like new I spent more on charger hdd hdd caddy but no lights come on . no sign of life anywhere on it . in addition, I was gonna part it out on ebay and noticed many more are having same problem. was wondering if there was a common issue? presario m2000 power problems?
  • chris gaines Nov 15, 2008
    thanks for info won't even try to power on. no lights period .. tvman66@yahoo.com
  • 108 Answers
RAM can become loose - I suggest re-seating the RAM.
G'luck
Posted on Nov 11, 2008
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
Hard disk faulty how to replace
The online guide is here:
http://www.scribd.com/doc/7994162/Compaq-Presario-M2000-Maintenance-and-Service-Guide
I would go to (page 2-5 of the manual above) first and run a Hard Drive test from the Tools menu, before replacing.
Then go to replacement procedures (Page 5-7 of the manual) and it will instruct you, it is very simple, usually taking out two screws, removing the caddy (plastic holder). You then unscrew the old hard drive from the caddy (four screws) and then screw in the new hard drive (four again), slide it in, screw the caddy in (two screws) and voila', your new hard drive is installed.
This does NOT include instructions on how to backup your files, re-install your software or anything OTHER than replacing the physical hard drive.
You will need to format the new drive and install an operating system and software.
If you need further instructions, please ask.
Sep 07, 2010 | Compaq Presario M2000 Notebook
Send me the laptop screen information
At first glance, we wouldn't elect the Compaq Presario M2000 the laptop we'd most enjoy cramming into a carry-on bag, but this economical desktop replacement is lighter than it looks, and it performs solidly.
The Compaq Presario M2000 is big and square--1.8 inches tall, 13.2 inches wide, and 11 inches deep--but it's very portable at 6.4 pounds. The power adapter adds less than a pound more.
Jun 01, 2010 | Compaq Presario M2000 Notebook
Have Presario M2000 need new scrren
Thats a little old to be putting $100 in for a new screen. Anyway on the bottom of that laptop u will see holes marked with a K those all need be removed there are two in the battery compartment and the screws under the rubber stops on the lcd screen bezel. There should be a video on utube to show you the rest but the keyboard top power bezel and lcd bezel have to be removed to replace the screen. The screens are pretty basic as for removal once you know where the screws are. Look for a donor latop on ebay to save money.
Mar 28, 2010 | Compaq Presario M2000 Notebook
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Presario m2000 no power
the same EXACT this happend to me! i didnt know what to do so i just a new charger at dell.com
Sep 12, 2008 | Compaq Presario M2000 Notebook
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
HP Compaq Presario V2000 Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
