Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu53 dishwasher fills slowly with water when turned off
I have a Bosch SHU 53 dishwasher & recently replaced the control board, It previously had the problem of counting down to 1 minute then not draining. That problem was fixed with the replacement of the control module. However it now seems to fill slowly with water when turned off & leaks all over the floor.
I ran the self test & did not get any fault codes.
  • Bill in Ballard Nov 15, 2008
    Problem solved....after watching the water slowly fill when the unit was not plugged in, I knew there had to be water leaking past the inlet valve. I replaced the valve. Problem solved. Fixed for less than $25. thank you, Bill
silly girl
  • 513 Answers
SOURCE: Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Posted on Mar 26, 2006
  • 213 Answers
SOURCE: Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Posted on Nov 20, 2007
SOURCE: Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Posted on Jul 04, 2008
SOURCE: bosch shu 9950
Take off the front panel (10 little screws, two shims will fall out) and you'll see the two handle bolts on the inside of the panel. Tighten 'em; reinstall the panel (good luck figuring out how the shims go back...)
Posted on Jan 13, 2009
  • 98 Answers
SOURCE: water in tray on bottom of dishwasher
There is a recall on the control board of many of these models, but your problem is likely not related. I have written a guide to help. It is here. Thanks!
Posted on Jul 19, 2009
Water in tray on bottom of dishwasher
Have you tried turning on the DW and holding the START reset button until you hear the water begin to drain out. This worked for me.
Jul 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 5302 Machine doesn,t fill with water.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 16, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Jan 05, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
My SHU53 only starts on 2Hr Delay and water is not getting hot
Bosch dishwashers run the heating element directly from the control module, which usually causes the solder joint to go bad.....solution, replace the control module, or take the old one out, and repair solder joint
Dec 27, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
Nov 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu5315 06
it sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Jun 05, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU 5300
Mine did that. I tried changing the timer but it didn't help. I noticed that the water level kept rising until the drain pump would be triggered by the overfill protection switch on the left side under the insulation. It turned out that the fill valve didn't close all the way and so the pan would never empty. A new fill valve (easy to install and cheap) fixed it!
May 11, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Timer runs down to 1 min and just hums water covers the bottom
need more info on problem does it start washing then run down and hum or what
Dec 26, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
269 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
