Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer putting out no heat
I noiticed a post you had put out back in april to someone with a similar problem.  This dryer was purchased in 05 and is out of warranty, but still relatively new, so I'd really like to keep the cost down and do it myself.  If you could help, I'd really appreciate it. Thanks DB
  • DougB3 Nov 19, 2008
    It's electric.  I think I found the problem though.  I ordered a fuse and thermostat and replaced the fuse and it seems to have solved the problem.  I still have the thermostat but didn't install it.
  • Anonymous Nov 23, 2008
    all seems to working fine with my electric dryer, but it just throws no heat, what should I do?
  • 41 Answers
Is this dryer gas or electric? Joe
Posted on Nov 18, 2008
Maytag Neptune Dryer purchased in 2001, Display shows 88, wont start . Can it be fixed?
There are 3 ways i know to make the machine work. Press and try all buttons to see if it clears up, Put a heating pad over the display for a few minutes. if these don't work. You will need a new display unit.
Hope this helps.
Dec 26, 2010 | Maytag Dryers
My Maytag Neptune dryer is showing an error code of 88. I have reset the circuit board, reset the dryer, but it wont turn on. Any help is appreciated.
Who ever posted put a heating pad on the display THANK YOU i put my wife's blow dryer on the back of the display and in 5 minutes its was working again THANKS AGAIN
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I need to locate the heating element in my Maytag MDE5500AYW Dryer. I had the front pulled off and could see the drum etc. But could not easily find the heating element and I am afraid to take off too much...
www.scribd.com/.../Maytag-Neptune-MAH3000AWW-Service-Manual
Please use these service manuals, above and below to help you locate your issue, inside these manuals are all diagrams etc.
www.servicematters.com/maytag_library/docs/16010061.pdf
Jun 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune electric dryer MDE5500AYQ not getting hot
You should get a diagram of your dryer *(look on the exterior back panel and under the top lid to see if they put a sticker diagram there.
Your heating element can be shorted open so no heat can be made.
You can easily check the element with continuity meter to see if it's broken. Then, check the part number from the Maytag website and price up a replacement. I would also check Ebay if the unti is older and you want to save some money on the part.
Good luck and be careful...always do your continuity checks with unit unplugged.
Jan 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
50 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
