Question about Compaq Presario 1626 Cooling Fan Case Cooling Fan
TOW FANS AGAINST THE RADIATOR, TOYOTA CAMRY 2001 4 CYL
ARE THEY BOTH CALLED RADIATOR FANS? THEY BOTH TO REDUCE THE HEAT FOR RADIATOR? THEY BOTH SHOULD SPIN WHEN THE CAR IS RUNNING? IF BOTH NOT SPIN IN ONE TIME, WHERE IS THE PROBLEM SHOULD BE?
  • 1 more comment
  • OIPINGNG Nov 11, 2008
    THKS FOR YOUR HELP
  • OIPINGNG Nov 13, 2008
    THANK YOU FOR YOUR HELP,
  • David Preston
    David Preston May 11, 2010
    Somehow this is getting labeled as a problem with a Compaq PC, when this is clearly a problem with a Toyota car.
    So this is being posted to computer experts and not automotive experts. Please try to get this posted in the appropriate category.
    Good luck and I hope you find the help you need
    Dave
    Genius:
  • 1,605 Answers
Yes, they are both radiator fan. dependent on the temperture of the outside air and the cooling temperure on control panel. the fan will kick on when the temperture cross over the preset- set on the computer. so, either fan on, no fan, fan is runing when the car is runing or not, is not a porblem.
the porblem occures when the fan stops, and the temperture is over 100 degree outside.
Posted on Nov 12, 2008
My 91 toyota Camery 4 cil man transmission seems to be running hot. I was going to put water in it and it had water but I noticed the radiator fan was not spining. will this make my car to over heat
yes your car will be over heat, just go to junk yard and open thermorstar sensor of another car to replace the old one that is cheap than you buy a new one ok!
May 30, 2014 | 1991 Toyota Camry
1998 Toyota Camry 4 cyl.only blows warm air from heater when car is unning for say ten min. When I start driving the temp gage goes down to cold and blows cool air, no heat. I changed thermostat and...
Your radiator cooling fan will only come on when the engine temp has reached the point where it needs to have air forced through the radiator and thus bring engine heat back down to safe operating range. If your heater is not working check to make sure the fresh air vents aren't stuck open (are the controls stiff or not going all the way across?) check also that the heater shutoff valve lever which is usually situated on the firewall at the rear of the engine and can be found easily by tracing the hoses back from the thermostat housing aren't bent and/or seized up.
Apr 08, 2017 | 2000 Toyota Camry
2000 Toyota Camry. The right side fan is not working what do i do
Your fan could of went up I would replace it or check your connections to your fan !
Jul 19, 2012 | 1991 Toyota Camry
Engine Cooling problem 1991 Toyota Camry 4 cyl
The cooling fan is controlled by a temp switch in the bottom of the radiator, try6 replacing this switch.
Apr 03, 2017 | 1991 Toyota Camry
Head gasket on the 1996 4 cyl toyota camry
go to the library and borrow a manual its not a very hard job but you will need a manual.
Jul 17, 2009 | 1996 Toyota Camry
1991 toyota camry. It has a new radiator and cap,
the a/c when running creates a lot of extra heat and needs second fan, if second fan is not working right this will cause overheating, if fan is creating a load noise it is likely bearing is bad and will not spin as fast as it should not cooling. also check that fan it not hitting anything if you describe loud noise i can give better idea
Jul 09, 2009 | 1991 Toyota Camry
I have a 1999 Toyota Camry (4 Cyl). It comes up
The sensor for the fans is in the rad at the bottom. T-stat may be bad or the rad may be clogged. Cooling system needs attention.
Jun 15, 2009 | 1999 Toyota Camry
Find get at the wire and plug for the oxygen sensor on 2001 toyota camry 4-cyl
Unbolt the pass side seat (only 4 14mm head bolts) and lay it back. This will give you the room you need to pull the carpet back from the console area and get to the plug.
Apr 12, 2009 | 2001 Toyota Camry
TOYOTA CAMRY 2001, WHEN SHOULD THE FANS SPIN?
when the car is running, there is enough air to cool the radiator, however, when when the AC kick on, the radiator absorb more of the heat from the AC coil. there by require more cooling. the 2 fan are there for that purpose.
as far as the smell of antifreeze, you nee to check all of the cooling hoses, in the engine compartment and under the dash. sound like there is a small leak some place.
Nov 11, 2008 | Compaq Presario 1626 Cooling Fan Case...
Compaq Presario 1626 Cooling Fan Case Cooling Fan Logo
311 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
