Question about RCA HDLP50W151 50" Rear Projection HDTV
RCA DLP 50'' TV Sound and Picture problem
I turn on the TV and it has no sound or picture. The green light indicator for "on" lights up and then flashes. As it is doing this there is a crackling and popping noise, it sounds like the fan is running and then shutting off. It will go thru this process repeatedly.
On light comes on then blinks, cracks and pops and fan powers up and then quits.
kw
  • pinbot33 Dec 06, 2008
    lamp was shot
  • dmxuser Jan 05, 2009
    your color wheel is going bad and RCA does not have a replacement available.
You need projection lamp.
Posted on Dec 03, 2008
No picture or sound on TV
Have you activated the self check this set has that will indicate what error was picked up?
Dec 20, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA DLP 50" NO PICTURE
hoping it's just the lamp - removed it, and it had blown, broken glass and all!
Jul 11, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
My RCA Scenium 50in. is not turning on!!
Its sounds as if the lamp has exploded or the color wheel has. I will post a link to a site that has a trouble shooting manual on CD called RCA DLP Disc #1 which covers every DLP in the ATC line which is what your model is. They have it either in cd form or they will email it. Its a very good resource for fixing your own set.
http://servicemanuals.vstore.ca/
Jun 16, 2008 | RCA HD50LPW175 50" HDTV
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
636 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
