Question about Dell PowerVault 110T LTO-2 Ultrium Tape Drive
The Error light is lit.
Error light blinks constantly and the Status light is on. I have cycled power on it several times and it still reverts to the same status. It does this with or without a tape inserted. Any ideas?
  • Dell Master
  • 1,056 Answers
I have 15 of these, and have had this happen 3 times (2 of them in brand new servers).
The first thing to try is updating the firmware (you can download it from the Dell site).
If that does not fix it, the next step is replacement.
In the 3 times I had it happen, that was the fix (we tried a number of different things previous).
Seems there was a long series of these drives being bad, replacement was the only cure.
If it's out of warranty, you may want to try contacting Ultrium.
Posted on Nov 11, 2008
  • Coss Nov 11, 2008
    Sorry, not Ultrium (it's still early here) That should be an IBM unit. You can check this on the information tag on the unit.
    If it is IBM made (which mine were) you can try contacting them.
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Status Light is constant red - I have already changed lamp. No Picture - How can I fix?
Press the Menu and the Device/input buttons both in together and see if the led blinks the two digit code of three blinks pause then followed by four blinks then it repeats the 34 blink several times. If so then the V26 Chassis power repair kit from will usually solve that issue. The kit contains the replacement capacitors and the CD with repair instructions.
Sep 24, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Status light is blinking red, power button orange nec vt700
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
Amber light on oki c3300 continues to flash and printer will not print
Here's what the owner's manual has to say:
Error status (Amber, blinking): you cannot continue to use the
printer. Intervention is required to recover from the error. Fatal
errors are irrecoverable and require a service call.
Blinking 1 (2S cycle)
An error has occurred but
printing can continue if you
press the ON LINE or CANCEL
Blinking 2 (500mS cycle)
An error has occurred. You
need to replace consumables
or remove jammed paper, for
example. The printer then
recovers from the error and
printing becomes possible
Blinking 3 (120mS cycle)
A serious error has occurred.
rebooting or a service call is
The Status Monitor in Windows provides a readable description
of the printer status corresponding to the indications of the
LEDs. In Mac, the printer driver provides status information
once you have sent a document to print. In Windows, if you
have the Status Monitor Preferences set to Pop up on alerts,
this readable message will be presented on screen whenever
an abnormal condition occurs.
There's no further information. Sorry.
Jul 19, 2011 | OKI C3400n Laser Printer
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
pleas install status monitor, that will tell you whats wrong.
May 29, 2008 | Konica Minolta magicolor 2400 Laser...
Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Dell PowerVault 110T LTO-2 Ultrium Tape Drive Logo
1,374 people viewed this question
Alun Cox
