Ricoh Aficio 1060 used toner bottle needs emptying
I have no manuals and I am stuck on where the used toner bottle is? The machine is telling me it needs to be emptied.
I have checked in what I consider the obvious places to no avail.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Look in the back right side of copier, there should be a door or a panel with a couple of screws. It is most likely triggered by weight, make sure you put it back correctly on the scale.
Posted on Nov 11, 2008
  • mreagan Feb 08, 2011
    The bottle is accessible from the front. Open the front door and look down at botton right for a black plastic screw. Pull this out and then you can slide the metal metal plate with the bottle attached. Pull out 5 inches and wiggle the bottle to make the toner settle. This should give a a while to have a technician replace the bottle.
How do i clear the toner amlmost empty message on ricoh mpc2800 , it still appears after i added toner in the bottles.
because the bottle is what the machine is looking for it cant tell that there is new toner in the bottle, it knows its new when the bottle is replaced go to store and buy a new bottle with toner in it.
Jun 12, 2015 | Ricoh Aficio Mpc2800 Digital Color Copy...
I've emptied the used toner bottle
Take the TONER CARTRIDGE out, and VERY CAREFULLY ,..... shake the hell out of it, refit and try it........ For shaking I put the cartridge in a Plastic Bag, seal, best I can so the Toner doe not come out and all over the place..... It is probably the HARDEST thing I know to clean up...... I have a Minolta Copier that is almost identical and this is what I do when it stops working
May 08, 2014 | Ricoh Aficio 3224C
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
How do i change the toner colection bottle for a Ricoh aficio 350 copier?
There is no toner collection bottle for the 350, used toner is stored in the transfer belt unit. It must be pulled from the machine disassembled then empty used toner reassemble and put back in machine, a counter must also be reset, cant remember which sp code this is though.
Sep 16, 2010 | Ricoh Aficio SP C410DN Laser Printer
USED TONER CASE IS NEARLY FULL
Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
May 06, 2009 | Ricoh Aficio 450 Copier
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
315 people viewed this question
jasbo
jasbo
