Our pc how to detect any hardwaregive the ans in the form of code
Computer system how to detect harddisk,floppy disk,cd rom and any usb? want the asn in the form of programming lang.that means i wat code for this.
    Problem Solver:
  • 5 Answers
Pero in que lenguage estas hablando?
Posted on Nov 12, 2008
Computer won't boot error code sata disk s/n 0F00-136B and many more???
looks like hardware failure.
find out what harddisk exactly you do have in the bios :
- press Del or F1 or F2 during booting, goto IDE devices, look for the model, size (in GB) etc.,
write down (the manufacturer could be: samsung, seagate, maxtor, fujitsu...)
- then change order of boot devices so that cd/dvd-rom drive and /or 3,5 '' floppy drive boots
before the harddisk, exit saving changes (F10 or Esc)
- then get diagnosis program from the harddisk manufacturer's homepage,
copy that to a bootable floppy disk or burn it to a cd-r/cd-rw which must be bootable
- boot from the cd or floppy, run diagnosis tool, both short and long test, what does it say then?
- if hardformat is available, perform one
- might work now, at least the hd will be recognized
-setup new windows installation.
have fun
Source : STAT DISK S/N 0F00-136B
Aug 16, 2012 | Dell Computers & Internet
Will not reboot
did u by chance change any settings in the bios.... if yes please change the settings.... if u donno hw to chnge the bios settings... please ask me...
Jun 07, 2008 | Compaq Presario 5000 PC Desktop
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Just wont boot saying contact medion could be hard drive or cd rom code no..........0 .c00000eg
Your bios setting has been changed. So just start your computer and keep pressing f2 or f8 or f12 or del button in either of the cases. When the bios window opens then you will see the boot menu somewhere in it and rearrange the boot sequence to harddisk then cd-rom then network and then usb (in some cases you can also make floppy disk.) This will resolve the problem but if your os is being corrupted then there is no option rather than the re installation of os (it occurs in some cases.)
May 18, 2010 | Computers & Internet
If the harddisk conected in your system are not dected
"ASSUMING YOU ARE USING A SATA HDD"
check the bios settings.....
if your hard disk detection is enabled or not...
if yes...(yet your system is not detecting your hard drive)
then....go the manufacturer's site and download the respective sata driver of your hdd (particular model number)...
burn it into a cd...
insert the cd into a usb cd rom/writer.....
then try to install windows.... let the system boots from the cd
at the time when it says "press f2 to install driver"
press f2...
then browse to the location i.i. usb cd - rom/writer and install the driver...
now your system will detect your hdd...
if this info is useful
don' t forget to say thanks...
Dec 16, 2009 | Computers & Internet
I have a eee asus laptop. I cannot startup the window at all. The pc show this message; "Windows could not start because the following file is missing or corrupt C:windowssystem32configsystem " how can i...
you have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
Jul 13, 2009 | ASUS Eee 4G Notebook
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
Make sure you dont have a floppy in the floppy drive inserted.
Also if you have a jump drive installed, plz unplug it.
But if you little computer savy. Go to your bios and make the boot sequence to first boot the Hard Drive
May 24, 2009 | Foxconn G31MX-K socket LGA775 motherboard
Won't boot off of the external drive
when u power on your system start tapping F2 key
you wil get system setup screen
it will be somthing like this
Boot Sequence The computer attempts to boot from the sequence of devices specified in this list.
Default Setting:
  • Onboard or USB floppy drive
  • Onboard SATA hard disk drive
  • Onboard IDE hard disk drive
  • Any add-in hard disk drives that are detected (listed in the order that they are detected with USB device usually being detected last)
  • Onboard or USB CD-ROM drive
  • Any other bootable add-in devices that are detected (listed in the order that they are detected with Onboard Network Controller usually being detected first)
Apr 12, 2008 | Dell Latitude X200 Notebook
Installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Jan 04, 2008 | Microsoft Windows 98 for PC
Usb devices not detected
Well, I am not sure about Hp photosmart, But most printers, Like all hard drives, you must install a CD-Rom disk in order to do this, I see that your CD-DVD-Drive was not working also, It should've came with a disk to install it on probably floppy, or your old driver, Hope this helps.
Nov 29, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
