Question about Acer Computers & Internet
ACER laptop. When the power button is pressed the light comes ON but it goes off within 2-3 seconds. The screen does not come ON. The fan comes on as long as the light is ON
  • babbra Nov 12, 2008
    Both. We managed to open the laptop and found the south bridge was getting rather warm in the short time the power is ON.
    The Fan stops after a few seconds. The the AC adaptor the Power LED is still ON. Nothing else works.
    Scholar:
  • 126 Answers
Hi babbra,
Does this happen with the ac power or on battery power or both?
Posted on Nov 11, 2008
  • Slick54 Nov 13, 2008
    Hi Babbra,
    If I understand you correctly, the Processor is getting warm immediately after the power is turned on and the fan stops after a few seconds. Sounds like the fan needs replacing. What is happening and why it's happening is because of a heat saftey feature built in to the motherboard. Once the laptop is powered up and the fan stops the heat temp is recognized in the bios as being too hot so the system will not boot.
    Replace the fan and let me know how it turns out.
Acer Travelmate 6592G Wont Startup
do the HARD reset. Disconnect the power adapter +battery. Hold the power button by 30 seconds. And then reinstall the power adapter and battery again and test again. this will solve the problem God bless you
Apr 04, 2013 | Acer TravelMate 6592G-602G25Mn Notebook
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
I press the power button on acer 5735 notebook the fan kicks in etc , then after a few seconds the power light goes back off before the computer boots up , what could e the cause ?
More than likely a virus or a video card. Hopefully the video card because if it is a virus then you will have to replace the hard drive. Hope this helps
Oct 21, 2009 | Acer Aspire 5735 Notebook
Acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 25, 2009 | Acer Aspire 5315 Notebook
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Acer 4520 Power up for 1 second and turns off
Can you hear the system fan running? If the fan fails, the PC shuts down itself to protect the processor from FRYING.
Apr 14, 2009 | Acer Aspire 4520-5582 Notebook
The notebook will not boot up. When the button is pressed, it lights up for about 10 seconds and then goes off. There is a faint hum which sounds like the fan starting up but that also stops when the...
sound like you have power problem mostly that is happen to the hp notebook now to solv
now you need to unplug the ac power and also remove the battery and press the power button and hold untell the light come on and plug it back in and also put your battery back on the notebook should work normal again
Dec 10, 2008 | Acer Aspire 7720 Notebook PC
Boot everytime
POBLEM WITH THE MOTHERBOARD...SORRY...
IF IT IS WITHIN WARRANTY TRY GET IT DONE THRU VENDOR IT WILL SAVE MONEY
May 22, 2008 | HP Compaq nx6125 Notebook
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
