Question about Philips HDD082 MP3 Player
Hd1620/05 could you tell me if you have a multi voltage adapter and charger for this model plz
    Scholar:
  • 120 Answers
Hello Justin1372, Personally i do not have a multi voltage adapter and charger for this model but if you type in google "buy multi voltage charger" you should be able to find something that works.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
I lost the dc adapter to my irulu expro x11. Unable to find the specific one. Would an adapter for the x1 or one that has several little plugs for it work?
There's 3 specs you need to match. First, there's the size of the plug. Next, there's the voltage. Then, there's the current. The voltage should be listed on the expro, along with the current required. The voltage should match, but the current for the adapter is the minimum you'll need. From the IRULU site, the charger is 5Volts DC and supplies 2 amps, so if your other charger supplies 2 Amps at 5 volts DC, it should work, if the tip fits. More than 2 amps will work. Less might not, or will charge it slower. The USB cable can also charge it, but usually takes a long time, and can not supply enough current for continuous operation, so the battery will drain in use. It can take half a day or more to charge it through USB on some models. The multi tip adapter can work if there is a tip that fits, but make sure you select the proper voltage, 5 volts, and watch the polarity, as the outer ring can usually be set for either positive or negative voltage. iRULU eXpro X1Plus 10 1 inch quad core tablet Android 5 1 Lollipop support...
Jan 26, 2017 | The Computers & Internet
Input 120v 60hz 25w output 3VDC 1500 mA I need a new transformer for an Acuvibe plug in class 2 Model D3-15A
Buy a generic multi voltage charger or any cell phone charger (they run on 3 volts) from a local electronics store or cell phone accessory shop, then solder and shrink tube your charging adapter onto the leak on the charger. You most likely can't buy the original charger. When you install the old charger end on the new charger end that plugs into your device make sure you pay attention to the polarity, one lead is market with a white stripe, one with none.
Sep 13, 2016 | Brookstone Mini USB Personal Massager
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
The charger isnt working
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Feb 22, 2013 | Computers & Internet
How do i fix an Acer aspire 4730z that will not charge the battery and has the charge light no longer comes on, is the motherboard bad?
Sep 09, 2012 | Acer Aspire Computers & Internet
Charger dont charge battery
The charge maybe faulty, use a multi-meter and check the voltage on the plug on the adapter. The output voltage should be printed on the label on the charger.
Apr 29, 2012 | Samsung For Cricket Indulge Car...
Car wont charge
Depending on how old the unit is,bateries only recharge for so long and will stop taking a charge.Try taking a multi meter and check the battery voltage and see if it even has any charge and if not check charger to make sure the charger has voltage coming out.You may need to replace charger.Multi meters are enexpensive at any Radio Shack and can tell you what is going on.
Mar 11, 2012 | Toys
LG enV3 battery will not charge. charger is plugged in.
Check power adapter’s DC plug that connects into the phonesocket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Nov 28, 2009 | LG enV VX9900 Cellular Phone
Will not turn on
Check the adapter with a multi-meter, the voltage on the connector plug should be slightly higher than the voltage that is printed on the label attached to the adapter.
OR
Borrow a working adapter, make sure it is the same or compatible to test your laptop.
Apr 14, 2009 | Gateway Computers & Internet
Philips HDD082 MP3 Player Logo
87 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
