Question about Sharp CV-P09FX Air Conditioner
Switch sticking on furnace blower
When the thermostat kicks off the air handler downstairs keeps running on furnace. have to hit it with my hand for it to stop
  • 49 Answers
Start by turning power off .clean contacts on switch then buy some dielectric grease put it on all moving parts even in contacks .or you can use graphite lubricant powdered .both can be found at hardware or auto parts store .had same problem
Posted on Feb 06, 2009
    Problem Solver:
  • 6 Answers
Need more info sounds like a sticky relay. unable to suggest a solution without more info on unit
Posted on Nov 11, 2008
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Can not get fan on to turn on. All else fine. heat only furnace. No air conditioning...only air circulation.I used to set it on "Cool" and "Fan On"and get air to circulate. Do I need new thermostat?
Since you have two thermostats that operate the heating unit and the fan, and the fact that neither will turn the blower on, I would suspect the furnace/ air handler. Turn the thermostat to heat and see if the heat and the fan comes on, if it does operate normally in heat, the fan relay or the high speed on the blower is most likely the culprit. (If the furnace is equipped with a circuit board, the fan relay is integral to the board, if it an older furnace it has a separate fan relay). If it does not operate normally in the heating mode, verify power to the furnace, see if the flame comes on, if it does: the fan motor, circuit board or the fan relay are most likely the cause. hope this helps!
Jul 20, 2015 | Heating & Cooling
Carrier electric furnace/air handler stopped running
Check fuses first! If yours is the model with a fuse box you will see a flap that pulls down to reveal a block of fuses, the blade fuse you described is part of it too! Are all fuses ok?
Nov 08, 2014 | Heating & Cooling
Carrier air handler/furnace won't turn on
from what your saying the motor is hot to touch if that is the case the motor is bad need to be replaced.
2 Rheem Protech 500 thermostats, 1 upstair & 1 downstairs with a Rudd Achiever 90Plus gas furnace. Thermostat downstairs works fine but upstairs one cycles fan on and off 2-3 times during heating...
Have you checked to make sure that all of the supply registers are open, the air filter is clean and nothing is blocking the return air grill?
It almost sounds like you could be cycling on a limit switch.
Usually on gas furnaces, the blower is controled by the onboard controls, in the cooling mode the thermostat will control the blower.
I would be looking past the thermostat, at the furnace it self.
I hope you find this helpful. If you continue to experience problems, please let us know and we will dig deeper. :)
Paul
Feb 13, 2010 | Ruud UBHC Air Conditioner
Why does my fan runs continus. and the condenser won't run out side.
The fan runs continously because your condensor is not kicking on and removing the heat. The thermostat needs to come under the set temp. to kick off the fan. If your compressor doesn't run and the fan on the outside unit does run, your compressor has an issue. If nothing runs outside, then your transformer on the inside unit(air handler) has an issue. This could also be a control relay on the condenser or the air handler.
Jan 15, 2010 | Omega Trane Furnace Draft Inducer Blower...
My air conditioner won't turn on. When thermostat is set to cool, the furnace blower kicks on but the compressor and outdoor fan do not.
sounds like your not getting a low voltage signal to the condenser, if your Air handler is in the attic check your secondary drain pan it might be off on the float switch, if your air handler is in a closet you need to check your float switch, it will have some wires coming out of it. Hope that helps you get started.
Apr 26, 2009 | Goodman CKL42AR42 Air Conditioner
My air handler comes on ,not the outside unit when my thermostat is in the off position even if i turn the thermostat down to 50 and have it turned off the air handler comes on for about 5 to 10 minutes...
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
Mar 28, 2009 | Carrier Heating & Cooling
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
Honeywell T8000C Thermostat Problem
If you have a volt meter, remove the thermostat off from the mounting plate and check for 24 volts AC across red (R) and White (W). Then check across Red and Yellow (Y). If you do not find any voltage, follow wire as much as you can all the way back to the air handler that is connected to it. Look inside and see if there is a small Auto (car) type of fuse in the wiring harness. Test and replace if necessary. Jump out the Red and Green terminals on the air handler and replace the door. See if the blower turns on. If so, you have narrowed it to the wiring to the thermostat. If not, you have a power problem and will need a technician.
Sep 28, 2007 | Heating & Cooling
Sharp CV-P09FX Air Conditioner Logo
77 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
