Question about Compaq Presario 2700 15" Flat Panel LCD Monitor
Led light turns on for a while and goes off
When i start my compaq presario 2700, the led light will light up for a short moment, and then goes off. this problem started after i have use the computer in safe mode, but before this time, the laptop will log on normally, and after a while it goes off unexpectedly without shutting down. i will be grateful if you can be of help to me.
  • Compaq Master
  • 3,422 Answers
Where is the LED< you never said. (exactly)
monitor or PC, ?
you posted a laptop to a forum called monitors
which is it, a laptop , desktop or only a monitor.?
toss coin, land LT. 2700 (legacy relic with square screen floppy and windows 98 first ones)
take out the battery , the big one, it must run forever on AC power pack or its a hardware problem. (there can be 2 main batteries)
1 bottom and on the right rear, CD out, and battery is its place.
yes, that is what they did then if you have it. I cant see yours.
Next do the HP long reset.
all batteries, out, now. (bottom big, right rear, out)
power pack out. disconnected.,
push the power button from 10 to 30 seconds, this is the HP classic, long reset in every manual they make and on there service page, 1st thing.
next is power pack, if still dead. the goal is getting the F10 key
BIOS to work first. it must work at all times at power on
power button on , hammer f10. and see bios
if fact it told you to press F10 for 16 years now, every day.
2001 laptops have zero value. now. zero. upgrade to 2008 is better, put this one in he trash. go to goodwill store upgrade for $20? (they wont want yours, sorry, its too old)
so do that. is bet but if maniacal. ? H3LL bent to spend $120 or more with a HDD bad, on a $1 PC, here goes.
OS + HDD = $170
if the screen is dead now say so, say totally black screen
what it did before it died, is not important unless the fan is dead is it? (all PC's ran ok before now)
then ask for help,
windows will shut done only if it is corrupted. (self)
hardware has many cause of shut down, about 10 causes.
one is the PC overheated from not cleaning it every year.
the run down. BSOD (black)
big battery out, AC pack only, got that?
this PC has a place for 2 main batteries both out now.
The PC has CMOS cOin cell, not one ever lasts 16 years.
so that be like the first thing id replace (basic service this is)
open bottom hatch cover to see it.
1: fan dead or all vent and to it blocked in lint as all are this old.
1b: fan dead not packed?
see slide show of nasty LT here.
http://www.pcdied.com/overheated.html
2: coin cell dead, above 2.9v ok, below never. remove it replace
3: power on hammer f10 the screen most show , "hit f10 to enter setup" if not bad screen or far worse (yes 3 billion transistors inside can fail, main board, or shorted modules inside up to 8)
4: now the flash light trick this old dog has CCFL back lamps.
do this.
http://www.pcdied.com/monitors.html#flashlighttest
if that shows DATA, then the CCFL are bad.
if no data now, the problem is more serious
http://pcdied.com/black-screen.html#Laptop
if it still is dead, we replace the power pack
or remove all modules in the PC that can short killing power dead.
any thing inside can short. 4 ways in fact, DC power, data, address or control buses. to find that we pull things, to find it.
ask. im not teaching Fault isolation checks here. but that last link above has it, see key word stripping there (control+F)
if all you wanted was to guess, say so, say no diagnosis guessing.
for that I say it needs to be cleaned of a pound of dust inside and new coin cell and dump the 2 useless main batteries, if both there.
led light turns on for a while and goes off - power-rzlrtvwphug01fp4xtvrxrj1-3-0.jpg left is power (both), right is battery failures.
for the coin cell, (its hard to get to on this PC)
read page 63 (pdf) here
the service manual. is here, for free, do not pay scalpers for it.
https://www.manualslib.com/download/273070/Hp-Compaq-2710p.html
Posted on Nov 01, 2017
2 Suggested Answers
Big Poppa Ma
  • 302 Answers
SOURCE: led light turns on for a while and goes off
sounds like your power supply is going bad
Posted on Dec 05, 2008
I have a compaq presario f700. its caps lock n scroll lock keys are functioning but light is not working wht could b the trouble???
most likely the led is blown.
short of stripping down the laptop to replace the leds,,, a pro job,,, just work away without them
Jun 23, 2011 | Compaq Presario 700 470024-192 Notebook
Hello, My Compaq Presario 750US will
The motherboard of your laptop might have encountered a short circuit. If you've already removed and reseated all possible removable parts and still get the same result, purchase a replacement motherboard or check if it is still under warranty.
Good luck.
May 17, 2011 | HP Compaq Presario F750US
My son also has a HP/Compaq Presario CQ61 and his too suffers from the problem mentioned by others - The p[ower light goes next to the power jack input goes out after a few seconds and the Laptop will not...
Have you tried a new power brick or tested the original?? it should measure around 19 volts and you should be able to draw at least 3 amps from it.
(Be aware that if you have a short circuit in the computer it could destroy another brick connected to it).
Mar 07, 2011 | Compaq Computers & Internet
Right hinge problem
Hi, here how to disassemble Presario 2700 computer and save money:
Click this:
How to Disassemble a Presario 2700 Notebook
Hope this helps. Please help me by voting and rating. Thanks. :)
May 12, 2010 | Compaq Presario 2700 Notebook
Compaq presario 2700, right hinge broken
You can buy hinges on Ebay. Make sure u get the hinge not the cover or support plate. then you have to take it apart and replace it. Not real easy but can be done by amature. Let me know if you need instructions. Be happy to help.
Mar 29, 2010 | Compaq Presario 2700 Notebook
My Compaq Presario f500 series Wont turn on anymore
I would like to help but it sounds like it's over heated and needs a repair guy to look at it
Jan 11, 2010 | Compaq Presario Notebook
Compaq Presario Laptop 2700 bios
you've got a corrupted file most likely,
but thus your computer managed to boot up before this thing show up on screen?
If yes try to go to safe mode by pressing F8 before it boots up then go to recovery or restore setting to earlier time before this thing happen.
If it does able to boot up after pressing the power then you'll have no choice but to reformat your hard drive, you can do this if you have other computer where you can attach your hardrive, but if none, much be better to bring it to service center
Oct 31, 2009 | Compaq Presario 2700 Notebook
Presario 2700 laptop silly question
Here is a link which shows you how to replace battery.
Its a video clip and i think it will help you.
Try Here
Thanks
Iqbal
Mar 17, 2008 | Compaq Presario 2700 Series (222123-001)...
Help compaq ex2200 wont turn on
You obviously have power, as lights and at least some text means power is connected ok, as you said. It may be a booting issue then. What OS is running on it when it did run???
Jan 12, 2008 | Compaq Presario 900 /1500 Series EVO...
Open Questions:
See all Compaq Presario 2700 15" Flat Panel LCD Monitor Questions
Compaq Presario 2700 15" Flat Panel LCD Monitor Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
