Question about Philips Televison & Video
I am looking to replace my TV with a Flat Screen LCD. This will be used in France in conjunction with a Skybox to receive Free to air transmissions. I believe the system used by the skybox is PAL. Are the Philips sets compatible with both PAL and SECAM (the French system) if purchased in the UK? Will the presence of a free to air tuner (UK) present any problems if used either with the Skybox or French free to air?
    Scholar:
  • 120 Answers
Edtwit, In my honest opinion, Philips does more than a campble job of adjusting to skybox's requirements. I would also suggest a adaptor if you find out that you need one of those too.
Overall it should be straight plug and play.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
I have just acquired a new lg tv as a free gift from sky. My problem is u can't tune it in either auto or manually. I don't have a aerial just hdmi skybox
You will not be able to tune in TV stations unless you first have a TV antenna installed. Once connected to a working antenna the set should find stations easily enough ?
But you do not need to tune anything in to use it with your skybox -simply connect the skybox to the TV using an HDMI cable (available anywhere that TV's are sold) noting the number of the HDMI socket that you plug in into on the TV. Then, using the TV's remote, set the TV to input signal from that input (HDMI 1 for example) and you should be fine?
Apr 14, 2016 | LG Televison & Video
JVC LT42E488 Color Issue
If you have a flat screen LCD TV then there is NO color tube. Somebody is blowing smoke. Don't deal with him. The main board in conjunction with the screen controller board are the places to look.
Dec 27, 2013 | JVC LT-42E488 LT42E488 42 inch 720p Flat...
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
Sep 11, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Does this TV have built in Freeview ?
Yes,all tvs that are a LCD or a Plama tvs that are a flat screen tvs picture panels can recieving Free over the AIR DTV broadcasting incomming tv channels.Buy and used a Digital design tv Atena for a long and strong recieving incomming tv free signal DTV channels.
Aug 15, 2011 | Philips 26PF8946 26 in. HD-Ready LCD...
I want to remove the text that appears on screen as people are speaking. How do I remove the text
U have the tv original remote wright?U are receiving and getting a Antena tv signal from free AIR DTV broadcasting channels?Yes,search ur tv remote for a button that said CC pushes that button a couple times make sure all functions like CC1,2,3.. to all off.If remote have no CC button,go into the tv menu look for Closed Captioning and Text like 1,2,3.. turn it all to off.The tv program Closed Captioning text on the screen will disapear.If ur are using Cable,Telicom,or satalite pay signals used their remotes.
Jul 18, 2011 | ViewSonic N2635w 26 in. LCD Television
HANNSPREE HSB 1115. TV. SHOWS RC. PULSES ARE RECEIVED BUT DOES NOT CARRY OUT FUNCTION. RC. CONTROL UNIT HAS NO EFFECT. OK MANUALLY, USING SKYBOX/SCART, ETC.
Of course you first tried replacing batteries in the remote? If so, take the remote to a TV repair shop and have them test that it's sending a signal. If it is working you'll have to open the unit and hook an o-scope (a good sensitive voltmeter may also be sufficient) to the IR receiver and see if you're receiving the signal. If that works there should be a signal line to send the command to the micro. This is usually the same line the keypad uses. Test individual components according to your results or simply repace the IR board if you're missing that signal. If you don't want to test anything you can just try replacing that board anyway. Good luck.
May 01, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
How can I connect an ATL850 8.5 in. LCD TV to a cable box?
You have a ATSC Digital tuner in your set which accepts over the AIR digital transmission. Your set does not have the ATSC QAM tuner to receive digital cable transmission. Those size sets are usually designed for outdoor use with an antenna and for camping ect.....Outside of that, go ahead and connect it and see what happens...Do auto program.
Jun 07, 2009 | Lasonic ATL850 8.5 in. LCD TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
