Question about Sony 0.7x Wide Conversion Lens for Cyber-shot DSC-F707 and DSC-F717 Digital Cameras
The lens is cloudy
Hello
I got back from my trip and noticed that I have a mostiure in my lens, I don't know it got there, the lens wasn't droped into water or anything likre that
what can I do?
    Problem Solver:
  • 5 Answers
Well the lens gets mositure even when it's in the bag, it's because of the humidity.
what I usually do when it happens is I put it in a hot dry area, like in the sun or somthing like that so the water can vaporize.
Posted on Nov 11, 2008
I have a reliant 606 electric water heater and I noticed that i wasn't getting any hot water. I shut the water off and look to see if i could see any problems. I cut the water on and notice that wate...
Problem is not clear:
Sounds like you have two different problems, but overheated water heater can cause both problems:
Before calling service technician, open following links for full do-it-yourself troubleshoot.
ADD A COMMENT for more details after looking at information below.
1) No hot water could be bad thermostat, or bad element, or circuit breaker is tripped.
Open following link to troubleshoot electrical problem with electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Leaking water heater.
Open following link to identify problem with illustrations and troubleshoot leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Look carefully at illustrations on page:
If drain valve is leaking, then put a garden hose cap on it.
If TP overflow pipe is leaking, do NOT cap that pipe
Jun 27, 2011 | RELIANCE ELECTRIC WATER HEATER
How do I disamble a TAMRON 28-80 aspherical lens. The inner lebs is cloudt/dirty
Sorry, you don't. It's a professional job only as you need lens calibration equipment which you won't possess.
In any case, if there's a cloudy element it's probably lens fungus. Lenses which are badly infested are best discarded as they're totally uneconomic to repair unless they are very high value specialist items. Yours isn't.
Jun 26, 2011 | Tamron AF 28-80mm Lens
Hello. I recently changed my water filter (puresource2) on a side by side. The water coming out now is cloudy. It looks like little white particles floating in the glass. I didn't notice it that...
If you can find a hose that will fit the water line you can flush it out. But the most likely problem is that the filter that you bought was defective and the white particles are coming for it. If you can test it without the filter, to see if the water is clear or not, will tell you whether you should take the filter back and complain.
Jun 08, 2011 | Frigidaire FRS23KF7AB Side by Side...
My son touched the lens and now it is cloudy. I tried cleaning it and it's a bit better, but too cloudy to take a pic. Any suggestions?
How are you cleaning it? You should only use photo lens tissue and photo lens cleaning fluid. Or better still, use a micro Lenspen. Can be purchased on the internet at sites like amazon.com
Feb 21, 2010 | Canon PowerShot A470 Digital Camera
Cloudy shots
What you want to know about cloudy Short?
Jan 31, 2010 | Canon PowerShot A620 Digital Camera
Trying to fix a damaged lens unit
lens parts can be purchased seperatly, so check witch parts need replacing and get a lens assembly diagram.
May 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Cloudy TV Screen
If you can remove the front screen, look down into each CRT tube lens, blue, green & red see which ones are cloudy. The cloudy ones need the fluid changed which is a coolant. Shops charge between $75 to $150 a tube to change.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Sony 0.7x Wide Conversion Lens for Cyber-shot DSC-F707 and DSC-F717 Digital Cameras Logo
224 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
