Question about HP iPAQ HX4700 Pocket PC
IPAQ HX4700 stylus falls out of pocket
IS there a spring or something that holds the stylus in? Mine must be broken. What to do???
SOURCE: antenna & stylus pen
ebay! They have tons of stylus pens. Do a search for HP Ipaq antennas on google. There are plenty of online stores that sell these.
Posted on Feb 24, 2008
SOURCE: Just a good HP iPAQ hx4700 Disassembly, Screen Removal and Repair guide
Thank you! This is a really good page!
Posted on Oct 13, 2008
  • 4 Answers
SOURCE: Replacing PDA Screen - HP iPAQ hx4700
http://www.repairhppda.com/video/How-to-Repair-for-HP-iPAQ-HX4700-HX4705-series.html
Posted on Mar 10, 2009
  • 6 Answers
SOURCE: My HP iPAQ hx4700 Pocket PC will not start up. It
Slider switches ok and pointing at the right place in the bottom?
1. Main battery possibly needs replacing.
2. Replace backup battery..
http://www.youtube.com/watch?v=cYwc_-ISnsA
Posted on Aug 31, 2009
  • 33 Answers
SOURCE: hp ipaq pocket pc 2003 screen broken
If you have the expertise to fix it your self, there are several places you can buy parts, here is one:
http://www.ipaqparts.com/index.html
If you would rather have it repaired, try here (same company):
http://www.ipaqrepair.com/
Posted on Dec 16, 2009
HP iPaq hx4700 Pocket PC
Here is the hp official link to the user guide:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00248348/c00248348.pdf
Thumb up!
Oct 23, 2011 | HP iPAQ HX4700 Pocket PC
I forget my password....so how should i break it?
the password can not be broken, but you can perform a hard reset that wipes the device clean including the password. all content is lost.
1. Press and hold the lower left and lower right buttons.
2. Press the Reset button on the bottom of the iPAQ Pocket PC
with the stylus.
3. Hold all buttons until the displayed image begins to fade
(approximately four seconds).
4. Release the program buttons and stylus.
You can verify a full reset by pressing the power button. If the
iPAQ Pocket PC has been fully reset, it will not turn on.
5. Reactivate the battery by doing one of the following:
Connecting the iPAQ Pocket PC to AC power
Pressing the Reset button with the stylus
Nov 06, 2010 | HP iPAQ H5450 Pocket PC
HP iPAQ hx4700 need default password
If you can't remember your passcode, you may have to do a hard reset(factory settings) if you have a sync folder on your computer, there is your backup. To do a hard reset: 1. Remove your iPAQ from the cradle, making sure that it's running on the internal battery power. 2. Use the stylus to press down the recessed reset button on the back or side of the iPAQ. 3. While the reset button is held down, press the On/Off button. 4. Release the reset button. When you press the On/Off button again, your iPAQ turns on and all your files are gone. To avoid repeating this major disaster in the future, you should back up your iPAQ files on your desktop PC. Activesync will generate another folder,and you will have to rename your pocket pc. But once your past that point, open both folders and drad and drop into the new folder. Hope this helps.
Jan 25, 2010 | HP iPAQ HX4700 Pocket PC
Jul 13, 2009 | HP iPAQ HX4700 Pocket PC
Jan 19, 2009 | HP iPAQ HX4700 Pocket PC
Back battery bad
There are two batteries. main and backup battery
the below video shows how to replace the backup battery, V6HR , of your hp ipaq hx4700
http://www.repairhppda.com/video/Repair-for-HP-iPAQ-HX4700-HX4705-backup-battery-replacement-guide-V6HR.html
Nov 26, 2008 | HP iPAQ HX4700 Pocket PC
HP Ipaq 4700 stylus problem
ask HP yet, we are not HP , sorry and this thing is legacy retired product , what good is it?
here is the real HP forum
see if you can get tears there.
https://h30434.www3.hp.com/
Dec 02, 2017 | HP iPAQ HX4700 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
