Breville ESP8XL Espresso Machine
Problem for Breville ESP8XL Espresso Machine
The pump works but the coffee maker won't eat up the water
By emmanuel_pou on Nov 11, 2008
The pump works but the coffee maker won't heat up the water so no steam is coming out. The orange light does not turn itself off. I don't know if the heater has gone bad. Can the heater be replaced? We need our expresso machine back and running! I guess we are hooked...
Comments:
Mar 18, 2009
- The heater wire was disconnected. The problem was resolved by simply connecting it. I beleive the vibration of the machine got it loose.
Clarification Request
Posted by vse222 on Mar 18, 2009
Is top of the espresso machine heated up? Or just stone cold?
Same Problem
May 26, 2009
-   I have the same problem where the heating light will not go out and the water does not heat up. It was mentioned that the heating wire may have come loose due to vibration. Where is the heating wire locatred and how do you get to it? -   tanderso
Feb 11, 2009
-   It was working the one day and the next...the heating light wont go off and obviously no hot water or steam but works otherwise. -   andyNjen
Popular Solutions for Breville ESP8XL Espresso
Questions and Unsolved Problems for Breville ESP8XL Espresso
Do you recommend Breville ESP8XL Espresso Machine?
Answer
Answer
Filters don't fit into filter holder. Can't put filter holder into place onto machine
Answer
My frother no longer functions. What should I do?
Answer
Why am I having difficulty getting a rich cup of coffee when I pack down the coffee in the filter
Answer
When I turn the dial to espresso it makes the sound that the steamer makes and no water comes out.
Answer
the little part were the cofee comes out from is clogged and the water and coffe comes out of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Breville ESP8XL Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2543
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
