Question about Frigidaire GLTR1670A Front Load Washer
Actually it's Frigidaire CRTR9300ASO Help Please
Frist, please excuse my lack of terms/parts, this is my first attempt at repairing a washing machine. This washer is just 4 years old and will fill with water, washing will begin, the dial will move but it never spins and ends with water in the washer. I have removed the drain hose cleaned it and the other hoses. I found a booby pin in the pump (the side the drain hose hooks into) I thought that might have been the problem so then re-installed the pump and it continued to do the same thing and sounded a bit like a loud whine. I removed the pump and and took it to a appliance part store, they checked the pump and said they felt it was working, however it sounded much louder then the new one they took from the box and tested, at least to me. They suggested the door latch may be the problem? I researched many posts here and the mentioned that the pump pully may be the issue? I suspect I need to take the pump apart to check that pully, is that correct? Would you suggest re-installing the pump once again and see what happens? I would really appreciate any help PLEASE! Thank You
  • 100 Answers
Your pump doesn't have a pulley. With the washer full of water if your put it on the spin cycle will it pump out water? If so pump is probably ok and the pressure switch thinks the washer is full of water and spends the whole spin cycle trying to pump water out. If not then your pump is plugged or bad and needs to be replaced.  If your dooe latch is bad your door lock light would not come on. So if it does come on in the spin cycle that part is probably fine.
Posted on Oct 30, 2007
Good evening, my frigidaire washing machine model #1659, is broken and its totally down and not working. My timer # 65247. Where can i buy this part. PleAse reply asap
I will suggest that you do a google search. for frigidaire washing machine parts . being world wide what I find may not help you asap
Jan 31, 2015 | Frigidaire Washing Machines
Frigidaire CRTR9300ASO won't spin replaced door latch switch and still does not work
Hi bitemejohne - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. Since you have already replaced the door lock assembly then the washer may be experiencing other issues. It could possibly have a faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 09, 2013 | Frigidaire GLTF2940ES Front Load Washer
Machine won't do anything and showing error 23
Sorry to read about your problem, I hope this helps you out.
An E23 error code on your Frigidaire washer indicates a failure of the drain pump relay.
Depending upon the model, your washer may be under warranty for up to 25 years, so check your warranty's status before attempting any repairs yourself.
    Try to Clear the Code
  1. A power outage can cause error codes to display on the screen, even if there's no problem. Hold down the "Cancel" button for three seconds, or unplug the machine briefly to see if the code goes away. If it returns, the problem is real.
  2. Check the Pump
  3. Unplug the machine and remove the service panel. Locate the pump on the floor of the machine, to the left of the tub, towards the front. Inspect the wiring for burns, breaks or loose connections, and replace as necessary. Use only appliance-grade wire.
  4. Replace the Control Panel
  5. If the wiring is fine, the problem is a severed relay on the control panel. Unfortunately, this cannot be repaired and must be replaced. Remove the control panel from the upper portion of the back of the machine, and replace with an identical part from Frigidaire.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer machine,when starting the frist cycle to began washing. the water fills the tub without shutting off when it reaches the set level.example small medium,or large loads.water keeps on running till it...
You have a bad pressure switch, or a hose to the pressure switch from the tub witch is bad or came loose.I would replace both neither is an expensive repair
Nov 16, 2010 | Frigidaire Washing Machines
Won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
May 21, 2010 | Frigidaire ATF6000ES Front Load Washer
My CRTR9300ASO Frigidaire Front Load Washer makes a loud thumping noise and moves slow spinning. Any ideas what might be wrong?
if you lucky, you have a broke shock absorber on the bottom. if your luck is not so good......well we will find out.
open the door on your washer. locate the big silver basket in the middle. put your hand in side and push up. now this will move but we are looking for it to feel very loose, not springy. if your luck is bad you will hear and feel it freely clunck around as if the inner basket is coming loose. if this is the case then you will be looking at a very expensive repair. like $350 and up
levi
Lebarchrigen Appliance Repair
www.lartoday.com
Dec 10, 2009 | Frigidaire GLTR1670A Front Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire front load washer will not spin
i was told when it won't spin, then the drain is plugged.  i opened mine up and found a sock stuck in the drain hose.  removed it and seems to be working well.
Sep 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Please help...
when water is turned back on does it run in without turning machine on? if so fill valve is probably bad if overflowing and washer is cut off and water stops suspect water level control
Aug 12, 2008 | Frigidaire Washing Machines
AFT 6700 - Brand new unit just dropped off code 31 in the display.
The problem with attempting repair on a new machine is that it can void the warranty. I'm sorry. You must be frustrated.
Jul 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
334 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
