Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune wont charge at all even when its plugged in
When its plugged in it seems to drain the battery even if its off i have had it plugged in for 4 days and nothings happened it wont even turn on what do i do??????¿¿¿¿¿¿¿
  • 7 Answers
OK this seems weird but if you have like a Nintendo Wii or a PlayStation 2 or 3 take you sync cable and plug your zune into the usb port on the system because sometimes the battery is just so dead that it dosent have enough power for the computer pick it up. mine done this a few days ago and i left it plugged into my Nintendo Wii over night and it started working again
Posted on Nov 14, 2008
My 120G zune wont wont even turn on. ive left it hooked up to my computer and wall-charger for days. and the reset methods dont work. help!!
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . You need new battery . If you replaced the battery with new one and the device still can't recharged , then I recommend you to take your player to the service .
good luck .
please rate !
Mar 30, 2010 | Microsoft Zune JS8-00001 Digital Media...
Totally dead Zune!
It sounds like you guys might be suffering from the Infamous zune new year bug. Let your Zune completely die (leave it for a few days if you have to). After doing this plug it into a computer or wall out let to charge. Leave it to charge for at least an hour. Come back and unpluge the zune and reconnect it to a different usb port if possible. Let it continue to charge.
Letting it die should fix the freeze and swapping ports during the charge will help the computer detect the zune as when their batteries are 100% dead they do not have enough power to say that they are there.
Hopefully this will help out one or two of you.
Jan 05, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune froze on boot up this morning. Reset buttons won't work nor will any others. Tried charging battery to no avail.
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
my zune just went black screen and will not recarge or anything else.
Nov 17, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune charging problems, hardware problems
I had a 30g w/same problem. I installed the Zune software from CD. Plugged the Zune into my USB jack and waited hrs for the full screen battery icon to go away. It never did. Here is what I did to fix it. I left the Zune disconnected until its battery drained and the lcd went dark. In this state, pressing the play/pause button, caused the full screen battery icon to appear briefly before the lcd went dark again. With the Zune disconnected from my xp pc, I ran Windows Update in express mode. I have Windows system restore and auto-update turned off and rarely update my pc, so I also took the opportunity to take a manual system check-point (so I could restore from the check-point if an update trashed my pc). I took and installed all the latest Windows updates. When it was done, I had all the latest security updates and IE 7. At this point I went to and downloaded the latest Zune software. I installed the Zune software update. I ran the new Zune software on my PC and found the device tab. NOW I connected the Zune to a USB port on the back of my PC. The full screen battery icon appeared on the Zune but nothing appeared in the Zune software. I left it this way for a few minutes. It occurred to me that I might get more power through the USB port if I turned off my other external USB devices, which I did. Within a few minutes, the Zune FINALLY came to life and a Zune splash screen appeared on the device. The device booted and was FINALLY recognized by the Zune software on my PC. Shortly after that I noticed that it already started synchronizing with my PC music collection. I figured it would charge up and download my entire collection (20gig) so I grabbed some sleep for a few hours. When I returned, the PC was asleep too. Unfortunately, the Zune was not charged and had stopped sync'ing. Not to be discouraged, I woke up the PC, exited the Zune software and left the device charging for an hour or so. When I returned, the device was about 80% charged. I quickly disconnected and played my first music video on the device!!!! I reconnected (the Zune software auto-launched) and left it sync'ing and charging for a while longer. When it was 100% charged, I disconnected and have been using it for a few hours. It was a long painfull road to get this thing setup, but it was WELL WORTH IT! I am already a huge fan of this device. In fact, I'm considering passing this one on to my wife so I can get the 80gig. Hang in there, it's worth it!!!!
PS: one sidebar -- I have noticed that the pc software will only sync about 800 songs in a session. I have simply been restarting the sync to get the next session going. At this point, I am fully synchronized and have 4.5 gig free.
Dec 27, 2007 | Microsoft Zune JS8-00001 Digital Media...
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
128 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
