Question about Philips 50P8341 50" Rear Projection Television
Bad color, faded out picture
We have had our TV for four years. We started having problems soon after we bought the TV. Had a repairman out to fix the problem. Helped for awhile. The picture has now gradually faded out and none of the adjustments do anything. We can not fix the problem. Also the whites are too bright and occassionally the faces have green splotches on them. The TV is way too big to transport and we are looking for a repairman that can come to our house to fix it. Can you help?
Linda Metzer
    Scholar:
  • 120 Answers
Hello emtzer, Typically, overtime your tv will become out of tune.
The way a display TV works is by shooting electromagnetic pluses through a vacuum guided by variations of magnetic stability.
What that means is overtime magnets tend to wear down thus resulting in a repairman call. Unless you are a expert in the field of tv repair i would also suggest for you to call them up and have them come fix it again. Although, though experiences and a budget, if you are able to upgrade to a LCD flatscreen I say do it. It will save money in electricity and the hassle of someone having to come fix your display.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
The color on my Advent TV fades in and out of the picture, and goes to black and white Why
The problem is in the picture tube board circuit. Sometimes the CRT socket doesnt connect well to the CRT pins. Or maybe there have bad solders from RGB transistors. check those transistors, Also the bad thermistor discolored the entire tv screen.
Sep 29, 2014 | Televison & Video
Tv will not switch on - when you press power on the remote the tv goes to switch itself on and then switches off straightaway
I've answered three of these so far, so this problem must be a very large manufacturer's defect big among large-screen LCD TVs of a bunch of different makes.
It's a power capacitor inside the TV that controls whether the power supply works or not. Our Samsung 46-inch started doing the same thing with about 2 months of a 2-year warranty left in it, and I'm glad we called the local retailer, because they were aware of this problem and gave us the number to Samsung, who paid to send a trained repairman about 60 miles to our house to fix it. During his repair, I helped him remove the large back cover, and set the TV on its face, and asked him about the problem. He detailed to me exactly what I said above, and also that it's been a very big problem with the rush to get new TVs out to market.
If your TV is still under warranty, jump on this situation before it runs out--it is a hardware problem, not fixable otherwise...
If it's out of warranty, your local TV repairman should be able to repair this for less than $100, easy (the part on ours was a $2 capacitor, the repairman said).
Hope this helps.
Feb 24, 2011 | LG 42LP1D 42 in. LCD HDTV
I have a Samsung ln46c630 which was purchased in May 2010. For the last few weeks it has started to have a strobing effect. Switching the source sometimes fixes the problem. It will run fine for a while...
Any luck? We bought our tv (same one) in March of last year. It is doing the exact same thing. Time Warner has already came out and switched out the cable box and cables. We have a tv tech coming soon (contracted out from Samsung, of course...) Problem persists...
Feb 06, 2011 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
My panasonic tv has started too have very bad picture problems colors of red blue green going thru the screen
Replace convergence ICs in tv by local tv repairman to fix tv problem as picture become very bad due to convergence chips failure.
Oct 13, 2010 | Panasonic Televison & Video
I have a KP-51ws520 that a friend gave up on and bought a new LCD TV. About a year ago, after a power outage in our neighborhood, this tv now has noticeable streaks across the screen at all times. Is...
It depends on what the problem actually is; are the streaks colors like red or blue outlines around lettering etc?
The more you tell me the better I can help. I will post a photo or two of what convergence problems look like.
This set is also prone to another problem, on a blank video input look at the screen: you should only see Video 1 (etc) and if you see faint curved lines (red, green or blue) and or the back ground is also wrong color you have the second problem.
let me know which it is.. If this information helped you rate this solution as very helpful as I do this here for free.
SD TECH
Aug 20, 2010 | Sony KP-51WS520 51" Rear Projection...
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
Aug 17, 2009 | Samsung HL-S5087W DLP TV
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
Tv shuts off for awhile then i can turn it back on immediately
hitachi is known for its problems and the best solution is to call a repairman out to repair it properly.i know thats not much help but its the only sure way to fix it and fix it right
Jan 21, 2009 | Televison & Video
Sony lcd tv picture starting to fade
Hello oilreddye,
This sony (KV-36FS120) is a flat screen CRT type Television not LCD. However the problem you are describing sounds like a CRT problem. I posted this before and I hope it is helpful to you,
This may be a CRT problem. From what it sounds like i.e. dim picture, colors not bright. If you have a background in electronics I would tell you to check the voltage levels on the CRT pins and compare them to the values on a schematic, however if you do not have a background in electronics, I would suggest you taking the TV to your local TV repair shop and have them troubleshoot your problem.
Here is a possible list of things that might be wrong:
1) CRT going bad (The shop can try CRT rejuvenation if needed)
2) High Voltage on the anode not at proper levels (The shop can check this with a HV probe)
3) Video output levels low (The shop can check the voltage and signal levels on the CRT socket board, and on the video amplifiers).
These are the three primary possible issues.
I hope this helps,
Thank you,
Shuttle83
Nov 21, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Philips 50P8341 50" Rear Projection Television Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
