Computers & Internet Logo
Posted on Apr 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp slimline s3000 goes immediately into sleep mode
Goes immediately into sleep mode
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Apr 09, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1060777
Points
15385
Try booting into Safe Mode then go into the Control Panel and change the Power Options.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Once safe mode is up click Start/Control Panel and look for Power Options.
5 Related Answers
A
Anonymous
  • Posted on Sep 10, 2007
SOURCE: Start up Probelms HP Pavilion Slimline
I'm the same guest from before and I've got my slimline back up and running. I found the solution somewhere else, can't remember where as I was on someone else's computer, but suggested a boot up problem with some USB devices. One suggestion was to power the computer down, unplug all USB devices and power it up again. The only USB device I had was an HP all-in-one printer/scanner. I unplugged that and the computer booted right up. Hope this helps!!
Anonymous
  • 160 Answers
  • Posted on Mar 25, 2008
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Anonymous
  • 300 Answers
  • Posted on Sep 18, 2008
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Anonymous
  • 59 Answers
  • Posted on Oct 24, 2008
SOURCE: I Have a HP Slimline
1. after pressing poer button repetedly press f 8 go to safe mode enable vga mode.
if that does not work
2. get a pcie, pci, or agp video less than $100.00 that should fix it unless the mobo is ging bad itself.
benwabnick
Ben Wabnick
  • 2404 Answers
  • Posted on Aug 19, 2009
SOURCE: HP Slimline Pavillion s3123w monitor going to sleep.
Sounds like the motherboard might be bad but go thru these steps.
Unseat and reseat the memory one stick at a time in each slot one at at time and turn on the computer after each stick reinsertion.
If that doesn't get the video to come back up then go ahead and unseat and reseat the CPU. Then try turning on the computer.
If that doesn't do it, make sure there is no power going to the hard drive or the dvd drive. Then try turning on the computer.
If you do all of these steps and you still have no video, then the motherboard is bad and would need to be replaced.
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-slimline-s3400-desktop-pc-series/3688715/model/3688723
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
http://www.pcdied.com/sleep-or-dim.html
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
http://www.pcdied.com/overheated.html
My computer hp s3700f keeps going black or sleep. Mode
Hello
You can prevent the computer from going into sleep or hibernation mode by going to the CONTROL PANEL - POWER SETTINGS.
Once here, change the settings to High Performance.
You can also go into advanced properties and manually change all of the settings - including when the hard drives go to sleep (I set this to NEVER), when the monitor will go to sleep (again, I set to never).
Computer won't use sleep mode anymore
Go to Advance Power Settings.
Set hard drive to turn off a minute or 2 before sleep.
Set Hybrid and Hibernate modes to "Off"
Under USB settings select "Disable"
Under Multimedia select "Allow ....." also setup your screen to turn off ( pick how long monitor will stay on. you can also try going into the bios and setting it to default. save and reboot. let me know if this helps.
1helpful
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
3helpful
2answers
Evesham ebox - Sleep function
Hi, Azrul here, from Malaysia. You can disable the sleep function for your HP Media Center m7250n before connecting to tv.
Go to control panel
then go to display
then go to power under the screen saver's tab
then set your power options to never go to sleep at any settings.
I Have a HP Slimline S3040. When I turn it on I get a message appear on the monitor saying on G** Signal, then the monitor goes to sleep?
Loch Hiam
Az.
Grand Canyon Tech
Grand Canyon Tech
