Question about Compaq Evo D500 PC Desktop
Windows sys.config.missing please my pc is giving me headache it all about the booting it tells me to intall the windows and click r for repairs
    Problem Solver:
  • 4 Answers
Hello, more than likely if you have not changed any configurations in your computer yourself recently, then you have a virus. Get protected immediately and if already protected, make sure your updates are up to date
Posted on Nov 20, 2008
Missing config sys
To repair missing or corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
May 11, 2013 | MSI Computers & Internet
I have an hp mini 210-1041nr running win xp and when I start it, the computer tells me Windows\System32\Config\System missing. I tried service pack 3 but it didn't work. Can u please help?
You need to get a Windows XP from someone and follow these instructions:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
If that doesn't work or you can't get into the repair console then With the XP disk you choose to install Windows XP and when you choose to install over the current XP installation you will be given the option to repair the current Windows installation and you won't lose all of your data.
Mar 01, 2011 | Computers & Internet
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
Windows could not start because the following file is missing or corrupt:
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Corrupt or missing: Windows\system\config
Helpful link: click here
Advanced xp startup trouble here
eMachines link
If you have reformatted the hard drive there's no windows there at the c partition anymore for you to boot into. If so, read about format and reinstall on google.
May 05, 2009 | E-Machines T2698 PC Desktop
Can't Access Config.Sys Files
You might have to repair or reload windows
Mar 16, 2009 | Sony VAIO VGN-BX760NS2 Notebook
\windows\system32\config\system missing or corrupt
You can do a refresh of your Windows OS, if you have Windows XP. You need to boot to your XP CD and do a repair. This will only restore the Windows OS files and you will not lose your personal data.
This should help. please rate my response.
Feb 17, 2009 | Gateway MX6440 Notebook
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Compaq Evo D500 PC Desktop Logo
37 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
