Question about Radio Shack Pro-95 Handheld Scanner
Zero Activity Is there someone out there that can help me with a Pro-64 Hypercan by Radio Shack. I pulled a number of frequencies off the web and entered them as best I know how and ---- nothing.
  • 120 Answers
First to check if your scanner receives try the weather station,it that works then check that your squelch control is not set too low, turn it up till the static from a channel that is not transmitting stops.Also check the antenna ,remove it and then put it back on.If none of this works try removeing the batteries for a few minutes and then putting them back in, or reset your scanner according to the instuctions in the users manual.
Posted on Jan 02, 2009
How do i program a pro-135 200 channel hand held scanner from radio shack
  1. 1. Press "MAN."
  2. 2. Press "ENT/PGM" to put the scanner in programming mode. You will see PGM appears.
  3. 3. Use the number keys to enter both the channel storage bank and the channel number you want to assign to a frequency.
  4. 4. Press "MAN."
  5. 5. Use the number keys to enter the frequency and don't forget decimal point.
  6. 6. Press "ENT/PGM" to store the frequency into the channel.
  7. 7. you just stored a frequency into a channel. Repeat steps above until you have your scanner programmed how you want.
  • Hope this helps.
Nov 26, 2011 | Radio Shack Radio Communications
Will not load webcam
Whar kind of OS do you have? Some web cams will not load with win 7. You need to got to the Radio shack web site to manually search the site for the drivers needed in the support area. I have the same problem with a creative live pro web cam (0884). And it isn't supported under win 7 while win xp pro does support it. Goo dluck! Email; me the model number and brand name of yor web cam and the OS of the machine you use, and if it is a 64 bit, 32 bit (or 86 Intel), and I will track down your drivers for you. OK?
James
Sep 14, 2010 | Radio Shack VGA PC Camera Webcam
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
How to program local frequencies? Radio Shack PRO-84
Press the HOLD key, then enter the number where you want to store the frequency, then press FUNC + PGM, the channel number comes up, use the number keys and ./CLR to enter the frequency, including the decimal point you want to store, press E to enter the frequency into the channel ...You can get your frequency's at www.RadioReference.com ...hope this was helpful..
May 26, 2010 | Radio Shack Pro-84 Handheld Scanner
Pro 106 police scanner I can't program it I have tried everything and can not get it programmed. nothing but static
Try this, press HOLD, then enter the channel you want to store the frequency, then press the FUNC and PGM button, the channel number appears, use the number key of the frequency including the decimal point, then press E to enter..you can get your frequency's at www.RadioReference.com ....hope this was helpful....
May 21, 2010 | Radio Shack Pro-96 Scanner
How do clear the scanner to re program it
Programming a frequency into a channel clears the previous channel entry, so there's really no need to "clear" the scanner for reprogramming. To eliminate an unwanted frequency, you can either press the LOCKOUT key to prevent the scanner from stopping on a specific channel, or you can "zero" a channel:
1. Press SCAN/MAN to stop
scanning.
2. Use the number keys to enter
the channel number (1-200)
you want to clear.
3. Press PGM. F=C appears.
4. Press 0 then ENT. The
frequency number changes to
000.0000 to indicate the
channel is cleared.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Nov 05, 2009 | Radio Shack Pro-82 Scanner
Police scanner frequencies/freelist
Radioreference.com. Go to their data base, Click on your state then your county. It will give you all police/fire ems frequencies.
Jun 13, 2009 | Radio Shack Pro-97 Handheld Scanner
Need to know how to program a radio shack pro-94 handheld scanner
press the "prog" key followed by the "Trunk" key then the number "1" key.
Press the "down arrow" key until you see the initials Ed on the screen
Press the "E" key.
Enter the frequencies (including the decimals)
you must press the E key and the Prog key after each frequency, after you finish entering your frequencies, press the scan key.
If you need to clear your scanner, turn it off, press and hold down the number 2 and number 9 keys, while holding them down turn the scanner back on, "clear" should start flashing on the screen, once "clear" stops flashing you can enter the frequencies.
Jan 03, 2009 | Radio Shack Pro-94 Scanner
Radio Shack Pro-95 Handheld Scanner Logo
80 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
