Question about NetGear DG834 Router
DG834 and DHCP
Hello. I've only got one computer connected to my router, do I need to set up DHCP anyway? Currently I am having problems connecting to my router.
  • KRISTIAN SORDO Nov 07, 2006
    Thanks for the reply. But what I wanted to know is if I needed to set up DHCP on my computer, despite of it not being networked. Also, I'm afraid it didn't come with a CD; I bought it refurbished on ebay.
    President:
  • 2,961 Answers
Both your pc and your router should be set to obtain IP addresses automatically in the DHCP settingss, if you are using the wizard on the cd this should do it for you. Try not to use windows repair connection as it sets it to the wrong ip address, as your system has to match the routers, eg router address 192.168.2.1 and your pc addresss 192.168.2.2.
Posted on Nov 07, 2006
  • andrew pester
    andrew pester Nov 08, 2006
    Yes you do need to set the DHCP so it will automatically give your pc an ip address, but make sure your pc is set to obtain an ip address automatically.
    If it's the first time you have used the network you will need to use te XP network wizard to enable file sharing.
  • andrew pester
    You should'nt need the driver, just type 192.168.0.1 in your internet browser address bar and you should get into the routers menu.
Speedstream 4100 cant connect
plug the computer into the modem testing dhcp
if it gets internet the modem is the dhcp server
the plug into router by itself disconnected it from modem testing dhcp if gets ip address and no internet it's the dhcp server
dhcp can be done by the modem or router. I bridged mode the modem and let the router do dhcp. of course the router must be pppoe for dsl. been years since I had DSL, hope it helps
Jul 07, 2017 | Siemens SpeedStream Modem (4100) (SS4100)
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
Wrt54g2 dhcp problem
You must enable the DHCP setting on wireless router if you've configured the computer's wireless adapter to obtain an IP address automatically. If not you will get the "failed to acquire an IP address" error when you try to connect to wireless network! Also don't forget to configure big enough IP range on router's DHCP setting, because the router won't be able to assign IP to 6 computers if you only configured 5 IP space on router.
May 18, 2011 | Computers & Internet
I have a wrt310n router and cannot get internet connectivity when trying to configure a wn2000rpt
is your wn2000rpt connected to the wrt310n or the modem? are you using DSL modem? if so you may need to call in DSL service provider to configure something on their side first. for router configuration, you need to use static IP on your computer in the same subnet of the default IP address of your router. did you configure it yet? if you already get in the configuration page, then try to use DHCP only on one router. if you are using DSL modem then you might need to choose PPPoE as the connection type. Then check the cable and reboot your computer. If your computer is configured as receiving DHCP IP address then make sure there is a DHCP on your router. Anyway, if you tell me the details of your modem and router make, model and connection and the operating system on your computer I can tell you more.
Apr 23, 2011 | Computers & Internet
Hello how do that intternt error code :052010
Error Code: 052010 The DHCP settings of the access point and DS don't appear to be compatible.
What to do:
Please check the DHCP settings of your router and try again. If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
  • Errors ending in 0 = connection file 1
  • Errors ending in 1 = connection file 2
  • Errors ending in 2 = connection file 3
  • Errors ending in 3 = Nintendo Wi-Fi USB Connector
If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific information on where to locate your router's DHCP settings.
What is DHCP?
DHCP is a setting, typically "enabled" by default, that lets your router automatically assign IP addresses to the devices connected to it. This option is a setting for advanced users, and normally should be set "enabled." If you prefer to have your router's DHCP set to "disable," you will need to enter a valid IP address on the Nintendo DS, through the "manual settings" option. For information on how to do this, click here.
Jan 08, 2010 | Nintendo DSi Black Console
Router is a Netgear WPN824v3. The problem I am
Chances are that the router is set to manually assign an address if it doesn't receive an IP from the DHCP server.
I would first try removing all the wireless profiles and creating them again.
Also a windows update may have broken any firewalls you currently have installed so disabling them is also a good idea, then turn back on when you get it to work.
Dec 02, 2009 | NetGear WGR614 Wireless Router
I got the linksys router problem which no problem at all when i connected to sg broad band . currently use it to connect to malaysia streamys broad band and problem occured. when i connect the router to...
For that you enter in linksys configuration page with 192.68.1.1
then enable dhcp .
Aso set WAN settings as your internet service provider settings.
For that you have to set DNS server and other settings as your malaysia streamys broad band settings.
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | Linksys Wireless-G Broadband Router
Hi im having bit trouble with my router it is a (f5d7231-4 the wireless connection works fine even though signal low,yet when i try connect another comp from it i keep gettin an ip conflictkeeps telling me...
Hello
do you have dhcp on your router or do you have static ip:n on your computers? sounds like you have same ipn on both computers. you should change it to DHCP. go control panel networks settings then rightclick on your connection and properties click tcp/ipv4 settings and properties, mark optain an ip address automatically, also set dns automatically.
Jul 02, 2009 | Belkin (F5D7231-4) Wireless Router
Can only connect 1 computer to 'net on router
rourke, you shouldn't be entering the same settings on both router and desktop. I should only be on the router. It seems like something with DHCP is misconfigured on your router. Make sure it (DHCP) is enabled.
Feb 07, 2009 | NetGear DG834 Router
Configuration for wi-fi
Yes its possible! first thing you need to do is call your ISP and ask what kind of connection type you have for your service then if your connection type is static connection yo need to ask for IP information regarding your service this is the connection type you need to set in your router, now if your service is Dynamic connection or DHCP you just need to hook up your router and set it to dhcp . i believe most router is set to dhcp as deafault settings so all you have to do is hook up you internet connection to your router. if your still having problem with your router you can call your router vendor support number, just give then your connection type and they will guide you regarding the router settings and how many computers you want get connected.
Nov 09, 2008 | NetGear DG834G Router
NetGear DG834 Router Logo
261 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
