Question about Thermador Ovens
Oven temp wil not go above 250°
I cleaned the oven two weeks ago and yesterday went to bake something at 350°. The oven took forever to heat up  and only got to 250°. We tried setting it at 450° and it still only went to 250°. It's a 2003 electric wall oven.
    Scholar:
  • 68 Answers
First, how did you clean it, with an automatic cleaning cycle or by hand?
First thing to do, unplug it from any wall power for 10 to 30 minutes, it may reset itself. Do that regardless if you hand cleaned, whatever.
If you hand cleaned, unplug the unit, or while it is attempting to reset, and check by gently pushing on the elements in the oven, you may have pulled one out of it's connection point in the back and causing a high resistance connection, also look for a thermostat that may have been moved or damaged during the cleaning, there is a sensor in the oven somewhere, and it sends back the data on temperature, make sure it did not get moved into or out of an airstream, or unplugged partially also.
Something had to have been moved or broken while cleaning accidently it is too much of coincidence.
If nothing works after these attempts, write me at wbwill@sbcglobal.net and give me more data on the unit and I will try and look up some more trouble shooting ideas for you.
Posted on Nov 11, 2008
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
My electric Samsung oven will not hold a temperature setting, especially on the bake setting. The oven seems to preheat fine and then when you put the food in, obviously the temp will drop because you open...
After finding a cheap one on Craig's and reading the problems I decided to roll the dice and buy this range. It has the exact problem described above. The owner had replaced the control module and temp probe with no luck. I hooked up the range and sure enough it would come up to temperature (let's say 350) then dropped back to below 200 and never recovered. Lots of relay clicking but no heat. I unplugged it, took off the back and sure enough, one of the connections to the bottom burner was burnt and the wire was laying in the bottom of the range. I cut the bad part off of the wire, added a new high temp stainless terminal reconnected and viola', it works fine now. Wonderful range for practically nothing. It took about 20 minutes to repair and cost $2.00 for the new terminal. Piece of cake. Take a look inside before you call someone. These terminals Samsung used are cheap, not crimped properly etc.... hope this helps! I'll change them all out tomorrow.
Jun 20, 2011 | Ovens
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
Ovens Logo
141 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
