Question about Lexmark C912 Led Printer
Replace toner how/where do i open the printer(lexmark C912) to replace a finished toner?
  • Anonymous Mar 26, 2014
    Toner light stays on after I replaced the toner. Tried holding down cancel button and opening front cover but that did't solve the problem
    Genius:
  • 1,605 Answers
To change the toner is little bit more complicated than other type of printer.
I am go to give you the link for C912 user manual, which explain how how the toner comes out and replace.
please the read the writeup before you start.
http://www.lexmark.com/publications/pdfs/lexmarkc912/eng/userref.pdf
good luck
Posted on Nov 11, 2008
    Genius:
  • 2,035 Answers
Please click here and the installation guide to install the toner cartridges ..
Good luck..
"981 Service Switch Error"
981 service switch error refers to BUD(belt up/down) clutch if the error essage is hard. it could be possible that someone could have playes with white CAM below the tranfer belt(behind the waste toner box) if you suspect that the cam was manually rotated, then you are in a big FIX. if not then it could be just a problem with the cam being worn out. in this scenario you cannot remove or reset the transfer belt as you normally do it. there is a special procedure to remove the transfer belt. try the following.
remove the waste toner box., fool the front door of the printer so that you can watch the transfer belt moving up/down. while you have the fron door open,
Turn off the printer, press and hold the go and return buttons on the printer , keep watching the shaft that show the position of the belt, once it moves, be fast enough to turn off the printer. If you were successful in this procedure , you can remove the belt from the printer without any problem. Make sure not to touch the white cam shaft. visually examine the internal mechanism of the shaft, if it is wornout replace it.
IF the white cam was turned manually then you might have to replace the BUD clutch.. which is the most difficult process in this machine....Wish you all the best.
Nov 12, 2010 | Lexmark C912 Led Printer
We have a lexmark c912 printer and it's leaving red smudges at the top and the bottom of the printed sheets. What to do?
This could be due to a bad Magenta Photoconductor. Try this link. http://bit.ly/c652sm It gives you a step by step guide on how to switch the Photoconductor so you can troubleshoot if the Magent photoconductor is damaged and needs to be replaced.
Feb 08, 2010 | Lexmark C522n Laser Printer
Lexmark C912 not reporting toner properly
print the status page make sure the revision level in the lower right corner is greater than 803.04 if its not go to lexmark to update the code if it is greater than. press the right arrow until reset toner Lvl appears in the display press select. use the right arrow to scroll through the colors to be reset. when you get tot the color you want to reset hit select it should give a brief message resseting toner then move to the next one. when finished you will need to power the machine down and back on again before the changes will take effect.
Nov 20, 2009 | Lexmark C912 Led Printer
Paper Type and weigth Fot Lexmark C912
Media paper weight: is 20lb or 75gsm.
Media type: card stock, envelopes, Glossy paper, Paper Labels, Plain Paper, Transparent.
Media size: A3, A4, A5, Banner up to 11.69"x36", Executive, JIS-B4, JIS-B5, Ledger, Letter, legal, Super Tabloid, B5, C4, C5 DL, 7 3/4 9, 10 Envelopes.
demension is in inches, you need to convert it to centermeter.
Oct 30, 2008 | Lexmark C912 Led Printer
Lexmark C912 LED Printer
replace the rip baord if the firmware download failed ie flashing firmware eprom has fialed
Sep 29, 2008 | Lexmark C912 Led Printer
Lexmark c912
980 error code is internal printer error. This is beyond users capability.
turn off the printer and check all cable connections.
turn on the printer, you need to call lexmark service, if the error return.
Jun 24, 2008 | Lexmark C912 Led Printer
Lexmark C912 dn LED laser
one of your print heads ahve failed ie printhead leds the but you uuslly find the printer lies so you may have to replace several of them
Jun 20, 2008 | Lexmark C912 Led Printer
Mirrored printing
I WOULD REPLACE PHOTODRUM usually this will fix it
Jan 17, 2008 | Lexmark C912 Led Printer
Lexmark C912
1> check or replace all of the data cables to the printer..... 2> shut off and unplug the printer from both the wall power and the computer for about 10 min, and reboot the computer as well 3> try reinstalling the printer driver software
Jul 27, 2006 | Lexmark C912fn Led Printer
Lexmark C912 Led Printer Logo
153 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
