Question about Audiovox SIRPNP1 SIRIUS Radio Receiver
Good signal , no display/sound from SIRPNP1
My Sirius SIRPNP1 receiver receives a good signal but the station display does not show and there is no sound coming through. A sharp tap on the front of the receiver has brought it back a few times but even this is failing. What is loose inside? Any suggestions?
SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
I am having the same problem, i was able to manually get about 37 channels by holding down the BND button which changed the mode to manual tuning which allowed me to manually move to individual stations. By going bak and forth I was able to add more stations, but once I got to channel 38 (which is not a used channel) I could not add more channels. I don't know if this will help you get a few more channels. I am going to try to call clarion to see if they can help, if you get it fixed, please post what you did. Thanks and hopefully we can get this fixed
Posted on Aug 13, 2007
SOURCE: sirius sportster sp-tk1, always displays "acquiring signal"
Same problem in RI too. Acquiring signal stays on the screen 24/7. My husband has the same Sportster. When I plug his into my car docking station, it works fine. When I plug mine in, it says "Acquiring signal". Does this mean my radio is dead?
Posted on Jan 06, 2008
  • 20 Answers
Hi guys!! I am a sirius satellite radio employee and unfortunately, when this happens (usually when the receiver is about 2 years old) the radio is pretty much shot. It is a common problem with the older sportster models, but not so much with the newer one. As the receivers are probably more than a year old, they are now out of warranty and the only resolution is to call us at sirius and say you want to cancel the subscription on the radio. When cancellation is imminent, we will offer to send you a replacement (although it will be a different unit not compatible with you current docking stations) at no cost to you. Sometimes an antenna replacement will actually stop the problem, but it will happen again very shortly afterward, and thus it is only a temp fix to a permanent problem. Hope this helps you out!!
Posted on Feb 20, 2008
  • 20 Answers
SOURCE: Power but no signal
I work for sirius so I know about all of these different issues and the most common one is the connections. It is imperative that the radios be connected to power with the cig lighter adapter. This adapter had circuitry in it that lowers the cars 12 volts to 5 volts which the sirius unit ooerates on. The old units were 12 volt and could hard wired into the vehicles fuse block, but all of the new radios operate on 5 volts. If this is not the issue with either of you then you have defective units. Being that all warranty replacement are with remanufactured units, your chance of getting a problematic unit increases after the initial return of your new unit.
SOURCE: 37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
Well I tried a cable amplifier & that solved my problem. I now get all HD channels without an HD cable box.
Posted on Oct 19, 2008
Have sirius and hands free phone features with sirius antennae. I do not get good signals from local FM or AM Radio stations. Why?
Sirius is a satellite biased service , so it uses a satellite antenna , local stations how ever don't use that antenna and use a dipole antenna , are both type antenna's connected to your radio , lots of installers don't bother to connect local antenna to new radio installs , im mean you got Sirius why'd you want local stuff anyway is there thinking
Oct 20, 2015 | Kenwood Car Audio & Video
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Jun 08, 2011 | Sirius Satellite Radio Sirius Starmate ST1...
When I connect the sirius radio to the docking station (sirius connect home kit) I can hear the sound for a few seconds then the docking process engages and I loose the sound. I have the tuner set to...
Hello, I am sorry about your issue. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-DS575 Receiver
Unit shows 3 bars for signal strength yet the
This is a very old radio, and your antenna could be shot too. Try another antenna first.
Mar 01, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
Jun 04, 2009 | Sirius Satellite Radio Receiver
Connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Feb 28, 2009 | Onkyo HTR500 Receiver
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Audiovox SIRPNP1 SIRIUS Radio Receiver Logo
43 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
